How define Delta y(or x) between two neighbor cells for boundary condition ?
Old   March 1, 2015, 11:41
Question How define Delta y(or x) between two neighbor cells for boundary condition ?
Hesam
rapierrz is on a distinguished road
Hi friends,
I want to add a boundary condition with below equation :
a*grad(phi)+b*grad(T)=0 at wall. a,b are constant and phi,T is scalarField.
grad(phi) is (phi-oldTime(phi))/delta y
How i can define delta y between two neighbor cells?
rapierrz is offline   Reply With Quote
Old   March 3, 2015, 14:20
Alex
zfaraday will become famous soon enough
I'm not sure if I understood well what you need, but if the delta you are referring is the face-center to cell-center distance you have to use the expression delta()
Web site where I present my Master's Thesis: foamingtime.wordpress.com
The case I talk about in this site was solved with chtMultiRegionSimpleFoam solver and involves radiation. Some basic tutorials are also resolved step by step in the web. If you are interested in these matters, you are invited to come in!
zfaraday is offline   Reply With Quote
Old   March 4, 2015, 01:00
Hesam
Hi Alex,
I want to calculate the space between mesh near the upper wall of a chanel
and it's neighbor cell.
for example : (T-oldTime(T))/y2-y1;
y1=y position of mesh near the wall
y2=y position of mesh near the Previous mesh.
thank you,
Old   March 6, 2022, 07:49
Kuang-Wu Lee
kuangwulee is on a distinguished road
Hello Rapierrz, have you found the answer to this? I need to calculate the distance between mesh points, for a self-defined variable, too.
Thanks in advance!
kuangwulee is offline   Reply With Quote
Old   March 15, 2022, 23:30
wuicylucy
wuicylucy is on a distinguished road
Thank you for your very good and helpful article. The information in the article will help me a lot
wordle solver tiny fishing
wuicylucy is offline   Reply With Quote
How to setup the wall boundary condition of maxwell_slip_velocity_x_full UDF? ailee0303 Fluent UDF and Scheme Programming 5 November 12, 2024 22:37
Species Mole and Mass Fraction Macro combustion FLUENT 18 February 5, 2024 13:23
HELP----Surface Reaction UDF Ashi Fluent UDF and Scheme Programming 1 May 19, 2020 22:13
udf problem eb.nabizadeh Fluent UDF and Scheme Programming 2 March 1, 2013 01:28
Installing OF 1.6 on Mac OS X gschaider OpenFOAM Installation 129 June 19, 2010 10:23
