How to map a sampled plane to a boundary patch? |
February 28, 2015, 13:55 |
Rajib Roy
Rep Power: 12 |
Dear Foamers,
I need to map fields a sampled plane to boundary patch of another case. For simplicity, I keep the physical dimension same, however, the number and orientation of the faces may vary. (For example, I took a plane sample of a channel mid section and want to use it as a inlet boundary condition for a wind tunnel test-section.) Advise and comments are highly appreciated. Thanks in advance. Rajib |
May 24, 2016, 22:55 |
Karelke Yu
Rep Power: 12 |
hi, Rajib. could you plz post your finally way to do this?
mapfileds, openfoam, planetopatch |
Problem with cyclic boundaries in Openfoam 1.5 | fs82 | OpenFOAM | 37 | November 29, 2024 11:15 |
[OpenFOAM.org] Compile OF 2.3 on Mac OS X .... the patch | gschaider | OpenFOAM Installation | 225 | August 25, 2015 20:43 |
[Other] Map runtime the field from an internal patch to a boundary patch | elerubios | OpenFOAM Meshing & Mesh Conversion | 0 | July 18, 2014 05:19 |
Question about heat transfer coefficient setting for CFX | Anna Tian | CFX | 1 | June 16, 2013 07:28 |
[blockMesh] Cyclic BC's: Possible face ordering problem? (Channel flow) | sega | OpenFOAM Meshing & Mesh Conversion | 3 | September 28, 2010 13:46 |
