Problem of creating only cellZone (no faceZone) using snappyHexMesh
Old   February 17, 2015, 14:54
Default Problem of creating only cellZone (no faceZone) using snappyHexMesh
Yuehan
wc34071209 is on a distinguished road
It seems that I can create a cellZone using something like this:
refinementSurfaces
    heater
        level (0 0);
        faceZone heater;
        faceType internal;
        cellZone heater;
        cellZoneInside inside;
However, the problem is that snappyHexMesh creates also a new boundary called heater and heater_slave, which I don't want to.
Even I set faceType as internal, I cannot avoid this problem.
So how can I create only a cellZone without add new boundaries?
wc34071209 is offline   Reply With Quote
Old   March 12, 2015, 20:02
Christos
cbarmpar is on a distinguished road
Try to remove the surface from the features subdictionary.
Also try to create an empty createPatch dictionary to clean up the patches
cbarmpar is offline   Reply With Quote
Old   May 19, 2015, 09:16
Eloïse
Eloise is on a distinguished road
I'm having snapping issues when trying something similar.
I have several searchablePlanes (parallel to each other) across my domain. I want the mesh to snap on all of those planes, but I don't need boundaries to be created.
Once the mesh is finished, I then remove all cells located below a plane of my choice (without having to remesh each time I need to split the mesh at a different height).
The problem with faceType internal; is that the planes are not properly snap. While if I use faceType baffle; the snap is good but I end up with walls across my domain.
Anyone knows how to get as good snap with faceType internal; as with faceType baffle;?
I can provide a small test-case if needed!
Thanks,
Eloïse
Eloise is offline   Reply With Quote
Old   November 16, 2015, 10:01
nasir musa yakubu
esujby is on a distinguished road
Hello Eloise,
I ve the same issue, however, if you remove "face type internal/baffle" command,and probably increase the refinement level of your block mesh dict, it might snap, i tried that first and it worked, but decomposing after mesh was an issue. and now that i am testing the case with the baffle or internal face type, the cell zones don't get properly refined. i don't know why
esujby is offline   Reply With Quote
Old   November 16, 2015, 10:26
Eloïse
I gave up exploring this option. I decided to insert a single searchable plane of type baffle in my mesh, and use this baffle to then split my mesh and keep only the side I'm interested in. I repeat the process if I want to split along another plane.
Regards,
Eloïse
Old   November 16, 2015, 21:58
nasir musa yakubu
interesting, i haven't tried that option actually. i would look into that now, so i am guessing for a 3D mesh, a searchable box of type baffle might be the case. i will give it a try and provide update.
cheers
[SOWFA] NREL SOWFA ABLTerrainSolver tutorial problem cico0815 OpenFOAM Community Contributions 36 February 3, 2022 12:54
[snappyHexMesh] SnappyHexMesh in Parallel problem swifty OpenFOAM Meshing & Mesh Conversion 10 November 6, 2015 05:40
mapFields Error with snappyHexMesh Source Added Layers sherif35 OpenFOAM Pre-Processing 0 September 29, 2014 18:01
[snappyHexMesh] Problem with snappyHexMesh giack OpenFOAM Meshing & Mesh Conversion 0 March 7, 2014 10:40
[snappyHexMesh] snappyHexMesh: problem meshing baffle (surface with zero thickness) julien.decharentenay OpenFOAM Meshing & Mesh Conversion 7 June 16, 2012 09:12
