Cyclic BC on cylinder: "Cannot match vectors to faces on both sides of patch"
Old   December 12, 2014, 06:48
Question Cyclic BC on cylinder: "Cannot match vectors to faces on both sides of patch"
Davide D.
dav.dap83 is on a distinguished road
Hi everyone,
I built an axis-symmetric wedge and selected cyclic BC on the wedge faces. BlockMesh actually builds the mesh, but returns an error:
--> FOAM Serious Error :
    From function cyclicPolyPatch::order(const primitivePatch&, labelList&, labelList&) const
    in file meshes/polyMesh/polyPatches/constraint/cyclic/cyclicPolyPatch.C at line 1402
    Patch:anticlock : Cannot match vectors to faces on both sides of patch
    Perhaps your faces do not match? The obj files written contain the current match.
Nevertheless, checkMesh returns "Mesh OK".
Can anyone explain what it means?
I am attaching the blockMesh file together with a snapshot of the mesh and the output of blockMesh and checkMesh commands.
Thank you in advance
blockMeshDict.txt
log_blockMesh.txt
log_checkMesh.txt
dav.dap83 is offline   Reply With Quote
blockmesh, cyclic bc, cylinder mesh, wedge
Compressor Simulation using rhoPimpleDyMFoam Jetfire OpenFOAM Running, Solving & CFD 107 December 9, 2014 14:38
[snappyHexMesh] SnappyHexMeshDict fabrizio OpenFOAM Meshing & Mesh Conversion 25 October 14, 2011 08:00
[Commercial meshers] Handling cyclic BC from gambit to openfoam for a cascade airfoil problem - OF 1.6 maverick OpenFOAM Meshing & Mesh Conversion 2 June 18, 2011 05:36
[mesh manipulation] local mesh refinement at channel geometries Kr_kim OpenFOAM Meshing & Mesh Conversion 6 February 9, 2010 15:25
Adaptive Mesh Refinement and Cyclic Boundary Conditions adona058 OpenFOAM Running, Solving & CFD 6 October 23, 2009 10:17
