February 22, 2015, 07:39 |
#21 |
ok
Rep Power: 14 |
Dear Nicolas,
lots of thanks for your last post. |
January 24, 2017, 16:51 |
OpenFoam to model coupled interaction of a fluid deforming a solid plastically
#22 |
Rep Power: 11 |
Hi all,
Thanks in advance for helping with this. Can OpenFOAM, or other open source derivatives or branches of OpenFOAM, model the simultaneous interaction of a fluid causing large plastic deformations in a solid? Imagine a water flowing around a very thin metal film causing the film to permanently deform even if the flow is stopped. Thanks, Hossein |
January 24, 2017, 19:13 |
#23 | |
Philip Cardiff
Rep Power: 34 |
I have some work in progress code that will work; if you PM me your email address then I will send you details. The large strain elasto-plastic solid solver is described at: A Lagrangian Cell-Centred Finite Volume Method for Metal Forming Simulation Best, Philip |
August 23, 2018, 15:23 |
#24 |
Misha
Rep Power: 8 |
Hello all,
I'm also looking for a way to model deformable surfaces (cloth) in fluid (air) to see how it deforms. I do have some (more) solid elements that would keep the cloth from flapping around wildly though. I'm feeling pretty pessimistic that I can find something that will do what I need, but I'm dreading the idea of writing up the code myself, so... here's to hoping someone else had the same requirements as me and already wrote something up. Best regards, Misha |
August 28, 2018, 13:56 |
#25 | |
Philip Cardiff
Rep Power: 34 |
For modelling a cloth, it will be thin and so will probably require a shell-element approach (even a membrane-style approach); currently, there is no out-of-the-box solver that I am aware of but I can point you in the right direction if you head down the dreaded code development path. Philip |
September 19, 2018, 10:23 |
#26 | |
Misha
Rep Power: 8 |
September 19, 2018, 13:32 |
#27 |
Philip Cardiff
Rep Power: 34 |
Hi Misha,
I suggest having a look at the following articles:
As regards the implementation in OpenFOAM, I think the finite area framework would be a good starting point. Best, Philip |
September 20, 2018, 13:05 |
#28 |
Misha
Rep Power: 8 |
Sweet! Thank you!
April 2, 2019, 19:29 |
#29 |
Andrew O. Winter
Rep Power: 11 |
Thanks for a nice thread documenting all of your contact work. It was very informative.
In case anyone cares, the previously provided link for Philip Cardiff's PhD thesis is no longer working. Use the following one instead. https://researchrepository.ucd.ie/handle/10197/7919 |
November 21, 2021, 14:54 |
#30 |
Andrew Bickerdike
Rep Power: 5 |
Hi Philip,
Did you manage to develop the code for the elastic membrane you mentioned? I am looking at the deformability of red blood cells and think the elastic membrane approach is a good place to start. Do you think it would be possible to implement such applications into the immersed boundary method? Best wishes, Andrew |
November 22, 2021, 08:05 |
#31 | |
Philip Cardiff
Rep Power: 34 |
You can find a finite area implementation of a Kirchhoff plate and related tutorials in solids4foam: Code:
/Users/philipc/foam/philipc-4.0/solids4foam/src/solids4FoamModels/solidModels/kirchhoffPlateSolid /Users/philipc/foam/philipc-4.0/solids4foam/tutorials/solids/beamsPlatesShells Interestingly also, OpenFOAM-v2012 also included a Kirchhoff plate implementation using the finite area method, see https://www.openfoam.com/news/main-n...er-and-physics. Apart from reading this page, I haven't looked into this in any more detail. The application of these methods to non-planar geometry may require extensions to the formulation (I have not looked into it). Combining this with the immersed boundary method (or even the overset method) should definitely work in theory but no doubt will require for coding. Essentially it is just the fluid model that needs to know about the immersed boundary (or overset) mesh, e.g. see: Code:
/Users/philipc/foam/philipc-4.0/solids4foam/src/solids4FoamModels/fluidModels/pimpleOversetFluid |
November 22, 2021, 10:26 |
#32 |
Andrew Bickerdike
Rep Power: 5 |
This is very helpful! Thanks Andrew |
April 21, 2023, 06:44 |
#33 |
Adrien
Rep Power: 8 |
Hi all,
These solidMechanics solvers look outstanding, thank you all for this thread. Nevertheless, whatever I do on the elasticFoam/slidingFrictionBall, or the anneau_plaque case you shared (both run well on foam-extended-5.0), the VTK I extract never moves in paraview... SimaEq rises, so contacts are registrered, but nothing moves ! Is there a trick or something ? |
April 21, 2023, 06:51 |
#34 | |
Philip Cardiff
Rep Power: 34 |
You need to use the "Warp By Vector" filter in ParaView with the displacement field to move the mesh to the deformed position. Philip |
April 21, 2023, 07:13 |
#35 | |
Adrien
Rep Power: 8 |
Thank you very much ! It is now working perfectly. One side question. I wanted to fund OF foundation, ESI or extended (I essentially use the second one). Foundation gives you the opportunity to give 5 000€, which is quite...High...And ESI didn't answer to this enquiry, like they didn't care. According to you, what is the best way to do it ? Cheers |
April 21, 2023, 08:14 |
#36 | |
Philip Cardiff
Rep Power: 34 |
September 23, 2023, 09:22 |
#37 |
Rep Power: 5 |
What plasticity models does OpenFoam have ?
OpenFOAM - Validation of Results | Ahmed | OpenFOAM Running, Solving & CFD | 10 | May 13, 2018 19:28 |
OpenFOAM Foundation releases OpenFOAM 2.2.2 | opencfd | OpenFOAM Announcements from ESI-OpenCFD | 0 | October 14, 2013 08:18 |
ESI-OpenCFD Releases OpenFOAM v2.2.0 | opencfd | OpenFOAM Announcements from ESI-OpenCFD | 13 | March 30, 2013 17:52 |
Critical errors during OpenFoam installation in OpenSuse 11.0 | amscosta | OpenFOAM | 5 | May 1, 2009 15:06 |
The OpenFOAM extensions project | mbeaudoin | OpenFOAM | 16 | October 9, 2007 10:33 |
