decomposePar problem: Cell 0contains face labels out of range |
October 25, 2015, 13:03 |
#21 |
nasir musa yakubu
Rep Power: 12 |
snappyhexmeshdict:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.4.0 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object snappyHexMeshDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // // Which of the steps to run castellatedMesh true; snap true; addLayers true; // Geometry. Definition of all surfaces. All surfaces are of class // searchableSurface. // Surfaces are used // - to specify refinement for any mesh cell intersecting it // - to specify refinement for any mesh cell inside/outside/near // - to 'snap' the mesh boundary to the surface geometry { inlet.stl { type triSurfaceMesh; name inlet; } outlet.stl { type triSurfaceMesh; name outlet; } lens.stl { type triSurfaceMesh; name lens; } bot.stl { type triSurfaceMesh; name bot; } top.stl { type triSurfaceMesh; name top; } s1.stl { type triSurfaceMesh; name s1; } s2.stl { type triSurfaceMesh; name s2; } s3.stl { type triSurfaceMesh; name s3; } s4.stl { type triSurfaceMesh; name s4; } s5.stl { type triSurfaceMesh; name s5; } s6.stl { type triSurfaceMesh; name s6; } s7.stl { type triSurfaceMesh; name s7; } s8.stl { type triSurfaceMesh; name s8; } s9.stl { type triSurfaceMesh; name s9; } s10.stl { type triSurfaceMesh; name s10; } s11.stl { type triSurfaceMesh; name s11; } s12.stl { type triSurfaceMesh; name s12; } s13.stl { type triSurfaceMesh; name s13; } s14.stl { type triSurfaceMesh; name s14; } s15.stl { type triSurfaceMesh; name s15; } insulator.stl { type triSurfaceMesh; name insulator; } volume.stl { type triSurfaceMesh; name volume; } }; // Settings for the castellatedMesh generation. castellatedMeshControls { // Refinement parameters // ~~~~~~~~~~~~~~~~~~~~~ // If local number of cells is >= maxLocalCells on any processor // switches from from refinement followed by balancing // (current method) to (weighted) balancing before refinement. maxLocalCells 20000000; // Overall cell limit (approximately). Refinement will stop immediately // upon reaching this number so a refinement level might not complete. // Note that this is the number of cells before removing the part which // is not 'visible' from the keepPoint. The final number of cells might // actually be a lot less. maxGlobalCells 160000000; // The surface refinement loop might spend lots of iterations // refining just a few cells. This setting will cause refinement // to stop if <= minimumRefine are selected for refinement. Note: // it will at least do one iteration (unless the number of cells // to refine is 0) minRefinementCells 0; // Number of buffer layers between different levels. // 1 means normal 2:1 refinement restriction, larger means slower // refinement. nCellsBetweenLevels 1; // Explicit feature edge refinement // ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ // Specifies a level for any cell intersected by its edges. // This is a featureEdgeMesh, read from constant/triSurface for now. features ( { file "inlet.eMesh"; level 5; } { file "outlet.eMesh"; level 5; } { file "lens.eMesh"; level 5; } { file "insulator.eMesh"; level 5; } { file "top.eMesh"; level 5; } { file "bot.eMesh"; level 5; } { file "s1.eMesh"; level 5; } { file "s2.eMesh"; level 5; } { file "s3.eMesh"; level 5; } { file "s4.eMesh"; level 5; } { file "s5.eMesh"; level 5; } { file "s6.eMesh"; level 5; } { file "s7.eMesh"; level 5; } { file "s8.eMesh"; level 5; } { file "s9.eMesh"; level 5; } { file "s10.eMesh"; level 5; } { file "s11.eMesh"; level 5; } { file "s12.eMesh"; level 5; } { file "s13.eMesh"; level 5; } { file "s14.eMesh"; level 5; } { file "s15.eMesh"; level 5; } ); // Surface based refinement // ~~~~~~~~~~~~~~~~~~~~~~~~ // Specifies two levels for every surface. The first is the minimum level, // every cell intersecting a surface gets refined up to the minimum level. // The second level is the maximum level. Cells that 'see' multiple // intersections where the intersections make an // angle > resolveFeatureAngle get refined up to the maximum level. refinementSurfaces { inlet { // Surface-wise min and max refinement level level (0 1); faceZone inlet; cellZone inlet; cellZoneInside inside; } outlet { // Surface-wise min and max refinement level level (0 1); faceZone outlet; cellZone outlet; cellZoneInside inside; } lens { // Surface-wise min and max refinement level level (5 5); faceZone lens; cellZone lens; cellZoneInside inside; } bot { // Surface-wise min and max refinement level level (5 5); faceZone bot; cellZone bot; cellZoneInside inside; } top { // Surface-wise min and max refinement level level (5 5); faceZone top; cellZone top; cellZoneInside inside; } insulator { // Surface-wise min and max refinement level level (5 5); faceZone insulator; cellZone insulator; cellZoneInside inside; } s1 { // Surface-wise min and max refinement level level (5 5); faceZone s1; cellZone s1; cellZoneInside inside; } s2 { // Surface-wise min and max refinement level level (5 5); faceZone s2; cellZone s2; cellZoneInside inside; } s3 { // Surface-wise min and max refinement level level (5 5); faceZone s3; cellZone s3; cellZoneInside inside; } s4 { // Surface-wise min and max refinement level level (5 5); faceZone s4; cellZone s4; cellZoneInside inside; } s5 { // Surface-wise min and max refinement level level (5 5); faceZone s5; cellZone s5; cellZoneInside inside; } s6 { // Surface-wise min and max refinement level level (5 5); faceZone s6; cellZone s6; cellZoneInside inside; } s7 { // Surface-wise min and max refinement level level (5 5); faceZone s7; cellZone s7; cellZoneInside inside; } s8 { // Surface-wise min and max refinement level level (5 5); faceZone s8; cellZone s8; cellZoneInside inside; } s9 { // Surface-wise min and max refinement level level (5 5); faceZone s9; cellZone s9; cellZoneInside inside; } s10 { // Surface-wise min and max refinement level level (5 5); faceZone s10; cellZone s10; cellZoneInside inside; } s11 { // Surface-wise min and max refinement level level (5 5); faceZone s11; cellZone s11; cellZoneInside inside; } s12 { // Surface-wise min and max refinement level level (5 5); faceZone s12; cellZone s12; cellZoneInside inside; } s13 { // Surface-wise min and max refinement level level (5 5); faceZone s13; cellZone s13; cellZoneInside inside; } s14 { // Surface-wise min and max refinement level level (5 5); faceZone s14; cellZone s14; cellZoneInside inside; } s15 { // Surface-wise min and max refinement level level (5 5); faceZone s15; cellZone s15; cellZoneInside inside; } } // Resolve sharp angles resolveFeatureAngle 180; // Region-wise refinement // ~~~~~~~~~~~~~~~~~~~~~~ // Specifies refinement level for cells in relation to a surface. One of // three modes // - distance. 'levels' specifies per distance to the surface the // wanted refinement level. The distances need to be specified in // descending order. // - inside. 'levels' is only one entry and only the level is used. All // cells inside the surface get refined up to the level. The surface // needs to be closed for this to be possible. // - outside. Same but cells outside. refinementRegions // In descending levels of fine-ness {volume {mode distance; levels ((0.0000001 5) (0.001 3) (0.01 2));}} // was ((0.001 4) (0.003 3) (0.01 2)) // Mesh selection // ~~~~~~~~~~~~~~ // After refinement patches get added for all refinementSurfaces and // all cells intersecting the surfaces get put into these patches. The // section reachable from the locationInMesh is kept. // NOTE: This point should never be on a face, always inside a cell, even // after refinement. locationInMesh (0.0724 0.0651937 0.0743597); // Whether any faceZones (as specified in the refinementSurfaces) // are only on the boundary of corresponding cellZones or also allow // free-standing zone faces. Not used if there are no faceZones. allowFreeStandingZoneFaces true; } // Settings for the snapping. snapControls { //- Number of patch smoothing iterations before finding correspondence // to surface nSmoothPatch 5; //was 3 //- Relative distance for points to be attracted by surface feature point // or edge. True distance is this factor times local // maximum edge length. tolerance 10; //was 5 //- Number of mesh displacement relaxation iterations. nSolveIter 30; //- Maximum number of snapping relaxation iterations. Should stop // before upon reaching a correct mesh. nRelaxIter 5; //was 5 //- Highly experimental and wip: number of feature edge snapping // iterations. Leave out altogether to disable. // Of limited use in this case since faceZone faces not handled. nFeatureSnapIter 10; // was 10 // New settings from openfoam 2.2 onwards for SHMesh implicitFeatureSnap true; // default is false - detects without doing surfaceFeatureExtract explicitFeatureSnap true; // default is true multiRegionFeatureSnap true; // deafault is false - detects features between multiple surfaces } // Settings for the layer addition. addLayersControls { relativeSizes true; // Per final patch (so not geometry!) the layer information layers { s1 {nSurfaceLayers 1;} // was 3 s2 {nSurfaceLayers 1;} // was 3 s3 {nSurfaceLayers 1;} // was 3 s4 {nSurfaceLayers 1;} // was 3 s5 {nSurfaceLayers 1;} // was 3 s6 {nSurfaceLayers 1;} // was 3 s7 {nSurfaceLayers 1;} // was 3 s8 {nSurfaceLayers 1;} // was 3 s9 {nSurfaceLayers 1;} // was 3 s10 {nSurfaceLayers 1;} // was 3 s11 {nSurfaceLayers 1;} // was 3 s12 {nSurfaceLayers 1;} // was 3 s13 {nSurfaceLayers 1;} // was 3 s14 {nSurfaceLayers 1;} // was 3 s15 {nSurfaceLayers 1;} // was 3 } // Expansion factor for layer mesh expansionRatio 1; //was 1.3 // Wanted thickness of final added cell layer. If multiple layers // is the thickness of the layer furthest away from the wall. // Relative to undistorted size of cell outside layer. // See relativeSizes parameter. finalLayerThickness 0.000025; //was 0 // Minimum thickness of cell layer. If for any reason layer // cannot be above minThickness do not add layer. // Relative to undistorted size of cell outside layer. minThickness 0.000025; //was 0.1 // If points get not extruded do nGrow layers of connected faces that are // also not grown. This helps convergence of the layer addition process // close to features. // Note: changed(corrected) w.r.t 17x! (didn't do anything in 17x) nGrow 0; // Advanced settings // When not to extrude surface. 0 is flat surface, 90 is when two faces // are perpendicular featureAngle 180; // Maximum number of snapping relaxation iterations. Should stop // before upon reaching a correct mesh. nRelaxIter 6; //was 3 // Number of smoothing iterations of surface normals nSmoothSurfaceNormals 5; //was 1 // Number of smoothing iterations of interior mesh movement direction nSmoothNormals 3; //was 3 // Smooth layer thickness over surface patches nSmoothThickness 5; //was 2 // Stop layer growth on highly warped cells maxFaceThicknessRatio 0.5; // Reduce layer growth where ratio thickness to medial // distance is large maxThicknessToMedialRatio 0.03; //was 1 // Angle used to pick up medial axis points // Note: changed(corrected) w.r.t 17x! 90 degrees corresponds to 130 in 17x. minMedianAxisAngle 90; // Create buffer region for new layer terminations nBufferCellsNoExtrude 0; // Overall max number of layer addition iterations. The mesher will exit // if it reaches this number of iterations; possibly with an illegal // mesh. nLayerIter 50; } // Generic mesh quality settings. At any undoable phase these determine // where to undo. meshQualityControls { maxNonOrtho 180; //was 95 maxBoundarySkewness 0.5; //was 20 maxInternalSkewness 0.5; //was 4 maxConcave 180; //was 80 minFlatness 0.5; //was 0.5 minVol 1e-100; //was 1e-15 minTetQuality 1e-100; // was 1e-15 minArea -1; minTwist 0.00000002; //was 0.002 minDeterminant 0.000001; //was 0.001 minFaceWeight 0.000001; //was 0.001 minVolRatio 0.0000001; // was 0.01 minTriangleTwist -1; // Advanced nSmoothScale 10; //was 4 errorReduction 1; // was 0.75 } // Advanced // Merge tolerance. Is fraction of overall bounding box of initial mesh. // Note: the write tolerance needs to be higher than this. mergeTolerance 1e-6; //was 1e-6 // ************************************************************************* // Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.4.0 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; note "mesh decomposition control dictionary"; location "system"; object decomposeParDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // numberOfSubdomains 16; //- Keep owner and neighbour on same processor for faces in zones: // preserveFaceZones (pgs insulator s1 s2 s3 s4 s5 s6 s7 s8 s9 s10 s11 s12 s13 s14 s15 bot top lens); // method scotch; method hierarchical; // method simple; // method manual; simpleCoeffs { n (2 4 2); delta 0.001; } hierarchicalCoeffs { n (2 4 2); delta 0.001; order xyz; } scotchCoeffs { //processorWeights //( // 1 // 1 // 1 // 1 // 1 // 1 // 1 // 1 // 1 // 1 // 1 // 1 // 1 // 1 // 1 // 1 //); //writeGraph true; //strategy "b"; } manualCoeffs { dataFile "decompositionData"; } //// Is the case distributed //distributed yes; //// Per slave (so nProcs-1 entries) the directory above the case. //roots //( // "/tmp" // "/tmp" //); // ************************************************************************* // Last edited by wyldckat; October 25, 2015 at 13:12. Reason: Added [CODE][/CODE] markers |
October 25, 2015, 13:21 |
#22 |
nasir musa yakubu
Rep Power: 12 |
boundary file:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.4.0 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class polyBoundaryMesh; location "constant/polyMesh"; object boundary; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // 42 ( inlet { type wall; inGroups 1(wall); nFaces 0; startFace 56040582; } inlet_slave { type wall; inGroups 1(wall); nFaces 0; startFace 56040582; } outlet { type wall; inGroups 1(wall); nFaces 0; startFace 56040582; } outlet_slave { type wall; inGroups 1(wall); nFaces 0; startFace 56040582; } lens { type wall; inGroups 1(wall); nFaces 0; startFace 56040582; } lens_slave { type wall; inGroups 1(wall); nFaces 0; startFace 56040582; } bot { type wall; inGroups 1(wall); nFaces 0; startFace 56040582; } bot_slave { type wall; inGroups 1(wall); nFaces 0; startFace 56040582; } top { type wall; inGroups 1(wall); nFaces 0; startFace 56040582; } top_slave { type wall; inGroups 1(wall); nFaces 0; startFace 56040582; } s1 { type wall; inGroups 1(wall); nFaces 0; startFace 56040582; } s1_slave { type wall; inGroups 1(wall); nFaces 0; startFace 56040582; } s2 { type wall; inGroups 1(wall); nFaces 0; startFace 56040582; } s2_slave { type wall; inGroups 1(wall); nFaces 0; startFace 56040582; } s3 { type wall; inGroups 1(wall); nFaces 0; startFace 56040582; } s3_slave { type wall; inGroups 1(wall); nFaces 0; startFace 56040582; } s4 { type wall; inGroups 1(wall); nFaces 0; startFace 56040582; } s4_slave { type wall; inGroups 1(wall); nFaces 0; startFace 56040582; } s5 { type wall; inGroups 1(wall); nFaces 0; startFace 56040582; } s5_slave { type wall; inGroups 1(wall); nFaces 0; startFace 56040582; } s6 { type wall; inGroups 1(wall); nFaces 0; startFace 56040582; } s6_slave { type wall; inGroups 1(wall); nFaces 0; startFace 56040582; } s7 { type wall; inGroups 1(wall); nFaces 0; startFace 56040582; } s7_slave { type wall; inGroups 1(wall); nFaces 0; startFace 56040582; } s8 { type wall; inGroups 1(wall); nFaces 0; startFace 56040582; } s8_slave { type wall; inGroups 1(wall); nFaces 0; startFace 56040582; } s9 { type wall; inGroups 1(wall); nFaces 0; startFace 56040582; } s9_slave { type wall; inGroups 1(wall); nFaces 0; startFace 56040582; } s10 { type wall; inGroups 1(wall); nFaces 0; startFace 56040582; } s10_slave { type wall; inGroups 1(wall); nFaces 0; startFace 56040582; } s11 { type wall; inGroups 1(wall); nFaces 0; startFace 56040582; } s11_slave { type wall; inGroups 1(wall); nFaces 0; startFace 56040582; } s12 { type wall; inGroups 1(wall); nFaces 0; startFace 56040582; } s12_slave { type wall; inGroups 1(wall); nFaces 0; startFace 56040582; } s13 { type wall; inGroups 1(wall); nFaces 0; startFace 56040582; } s13_slave { type wall; inGroups 1(wall); nFaces 0; startFace 56040582; } s14 { type wall; inGroups 1(wall); nFaces 0; startFace 56040582; } s14_slave { type wall; inGroups 1(wall); nFaces 0; startFace 56040582; } s15 { type wall; inGroups 1(wall); nFaces 0; startFace 56040582; } s15_slave { type wall; inGroups 1(wall); nFaces 0; startFace 56040582; } insulator { type wall; inGroups 1(wall); nFaces 0; startFace 56040582; } insulator_slave { type wall; inGroups 1(wall); nFaces 0; startFace 56040582; } ) // ************************************************************************* // Last edited by wyldckat; October 25, 2015 at 13:24. Reason: Added [CODE][/CODE] markers |
October 25, 2015, 13:23 |
#23 | |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Quick answer:
This means that you should have executed it like this: Code:
reconstructParMesh -constant -fullMatch
October 26, 2015, 06:43 |
#24 |
nasir musa yakubu
Rep Power: 12 |
Hello Bruno,
Thanks again for your prompt reply, i did try the method you suggested but i still get the same error message for some reason. please have a look at the extract: Code:
Writing mesh to time constant Wrote mesh in = 92.43 s. Layers added in = 92.44 s. Checking final mesh ... Checking faces in error : faces with face pyramid volume < 1e-100 : 0 faces with face-decomposition tet quality < 1e-100 : 0 faces with skewness > 0.5 (internal) or 0.5 (boundary) : 31 faces with interpolation weights (0..1) < 1e-06 : 0 faces with volume ratio of neighbour cells < 1e-07 : 0 faces with face twist < 2e-08 : 0 faces on cells with determinant < 1e-06 : 0 Finished meshing with 31 illegal faces (concave, zero area or negative cell pyramid volume) Finished meshing in = 35900.4 s. End Finalising parallel run parallels@ubuntu:~/OpenFOAM-2.4.0/receiver$ reconstructParMesh -constant -fullMatch /*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.4.0 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 2.4.0-f0842aea0e77 Exec : reconstructParMesh -constant -fullMatch Date : Oct 26 2015 Time : 10:03:17 Host : "ubuntu" PID : 28364 Case : /home/parallels/OpenFOAM-2.4.0/receiver nProcs : 1 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster allowSystemOperations : Allowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time This is an experimental tool which tries to merge individual processor meshes back into one master mesh. Use it if the original master mesh has been deleted or if the processor meshes have been modified (topology change). This tool will write the resulting mesh to a new time step and construct xxxxProcAddressing files in the processor meshes so reconstructPar can be used to regenerate the fields on the master mesh. Not well tested & use at your own risk! Merge tolerance : 1e-07 Write tolerance : 1e-07 Doing geometric matching on all boundary faces. Found 16 processor directories Reading database "receiver/processor0" Reading database "receiver/processor1" Reading database "receiver/processor2" Reading database "receiver/processor3" Reading database "receiver/processor4" Reading database "receiver/processor5" Reading database "receiver/processor6" Reading database "receiver/processor7" Reading database "receiver/processor8" Reading database "receiver/processor9" Reading database "receiver/processor10" Reading database "receiver/processor11" Reading database "receiver/processor12" Reading database "receiver/processor13" Reading database "receiver/processor14" Reading database "receiver/processor15" Time = constant Reading points from "receiver/processor0" for time = constant Reading points from "receiver/processor1" for time = constant Reading points from "receiver/processor2" for time = constant Reading points from "receiver/processor3" for time = constant Reading points from "receiver/processor4" for time = constant Reading points from "receiver/processor5" for time = constant Reading points from "receiver/processor6" for time = constant Reading points from "receiver/processor7" for time = constant Reading points from "receiver/processor8" for time = constant Reading points from "receiver/processor9" for time = constant Reading points from "receiver/processor10" for time = constant Reading points from "receiver/processor11" for time = constant Reading points from "receiver/processor12" for time = constant Reading points from "receiver/processor13" for time = constant Reading points from "receiver/processor14" for time = constant Reading points from "receiver/processor15" for time = constant Overall mesh bounding box : (-1.646242e-90 -4.126551e-38 0) (0.08 0.07 0.08) Relative tolerance : 1e-07 Absolute matching distance : 1.330413e-08 Constructing empty mesh to add to. Reading mesh to add from "receiver/processor0" for time = constant Adding to master mesh Reading mesh to add from "receiver/processor1" for time = constant Adding to master mesh Reading mesh to add from "receiver/processor2" for time = constant Adding to master mesh Reading mesh to add from "receiver/processor3" for time = constant Adding to master mesh Reading mesh to add from "receiver/processor4" for time = constant Adding to master mesh Reading mesh to add from "receiver/processor5" for time = constant Adding to master mesh Reading mesh to add from "receiver/processor6" for time = constant Adding to master mesh Reading mesh to add from "receiver/processor7" for time = constant Adding to master mesh Reading mesh to add from "receiver/processor8" for time = constant Adding to master mesh Reading mesh to add from "receiver/processor9" for time = constant Adding to master mesh Reading mesh to add from "receiver/processor10" for time = constant Adding to master mesh Reading mesh to add from "receiver/processor11" for time = constant Adding to master mesh Reading mesh to add from "receiver/processor12" for time = constant Adding to master mesh Reading mesh to add from "receiver/processor13" for time = constant Adding to master mesh Reading mesh to add from "receiver/processor14" for time = constant Adding to master mesh Reading mesh to add from "receiver/processor15" for time = constant Adding to master mesh mergeSharedPoints : detected 0 points that are to be merged. Writing merged mesh to "/home/parallels/OpenFOAM-2.4.0/receiver/constant" Reconstructing the addressing from the processor meshes to the newly reconstructed mesh Reading processor 0 mesh from "receiver/processor0" Writing pointProcAddressing to "receiver/processor0/constant/polyMesh" Writing faceProcAddressing to "receiver/processor0/constant/polyMesh" Writing cellProcAddressing to "receiver/processor0/constant/polyMesh" Writing boundaryProcAddressing to "receiver/processor0/constant/polyMesh" Reading processor 1 mesh from "receiver/processor1" Writing pointProcAddressing to "receiver/processor1/constant/polyMesh" Writing faceProcAddressing to "receiver/processor1/constant/polyMesh" Writing cellProcAddressing to "receiver/processor1/constant/polyMesh" Writing boundaryProcAddressing to "receiver/processor1/constant/polyMesh" Reading processor 2 mesh from "receiver/processor2" Writing pointProcAddressing to "receiver/processor2/constant/polyMesh" Writing faceProcAddressing to "receiver/processor2/constant/polyMesh" Writing cellProcAddressing to "receiver/processor2/constant/polyMesh" Writing boundaryProcAddressing to "receiver/processor2/constant/polyMesh" Reading processor 3 mesh from "receiver/processor3" Writing pointProcAddressing to "receiver/processor3/constant/polyMesh" Writing faceProcAddressing to "receiver/processor3/constant/polyMesh" Writing cellProcAddressing to "receiver/processor3/constant/polyMesh" Writing boundaryProcAddressing to "receiver/processor3/constant/polyMesh" Reading processor 4 mesh from "receiver/processor4" Writing pointProcAddressing to "receiver/processor4/constant/polyMesh" Writing faceProcAddressing to "receiver/processor4/constant/polyMesh" Writing cellProcAddressing to "receiver/processor4/constant/polyMesh" Writing boundaryProcAddressing to "receiver/processor4/constant/polyMesh" Reading processor 5 mesh from "receiver/processor5" Writing pointProcAddressing to "receiver/processor5/constant/polyMesh" Writing faceProcAddressing to "receiver/processor5/constant/polyMesh" Writing cellProcAddressing to "receiver/processor5/constant/polyMesh" Writing boundaryProcAddressing to "receiver/processor5/constant/polyMesh" Reading processor 6 mesh from "receiver/processor6" Writing pointProcAddressing to "receiver/processor6/constant/polyMesh" Writing faceProcAddressing to "receiver/processor6/constant/polyMesh" Writing cellProcAddressing to "receiver/processor6/constant/polyMesh" Writing boundaryProcAddressing to "receiver/processor6/constant/polyMesh" Reading processor 7 mesh from "receiver/processor7" Writing pointProcAddressing to "receiver/processor7/constant/polyMesh" Writing faceProcAddressing to "receiver/processor7/constant/polyMesh" Writing cellProcAddressing to "receiver/processor7/constant/polyMesh" Writing boundaryProcAddressing to "receiver/processor7/constant/polyMesh" Reading processor 8 mesh from "receiver/processor8" Writing pointProcAddressing to "receiver/processor8/constant/polyMesh" Writing faceProcAddressing to "receiver/processor8/constant/polyMesh" Writing cellProcAddressing to "receiver/processor8/constant/polyMesh" Writing boundaryProcAddressing to "receiver/processor8/constant/polyMesh" Reading processor 9 mesh from "receiver/processor9" Writing pointProcAddressing to "receiver/processor9/constant/polyMesh" Writing faceProcAddressing to "receiver/processor9/constant/polyMesh" Writing cellProcAddressing to "receiver/processor9/constant/polyMesh" Writing boundaryProcAddressing to "receiver/processor9/constant/polyMesh" Reading processor 10 mesh from "receiver/processor10" Writing pointProcAddressing to "receiver/processor10/constant/polyMesh" Writing faceProcAddressing to "receiver/processor10/constant/polyMesh" Writing cellProcAddressing to "receiver/processor10/constant/polyMesh" Writing boundaryProcAddressing to "receiver/processor10/constant/polyMesh" Reading processor 11 mesh from "receiver/processor11" Writing pointProcAddressing to "receiver/processor11/constant/polyMesh" Writing faceProcAddressing to "receiver/processor11/constant/polyMesh" Writing cellProcAddressing to "receiver/processor11/constant/polyMesh" Writing boundaryProcAddressing to "receiver/processor11/constant/polyMesh" Reading processor 12 mesh from "receiver/processor12" Writing pointProcAddressing to "receiver/processor12/constant/polyMesh" Writing faceProcAddressing to "receiver/processor12/constant/polyMesh" Writing cellProcAddressing to "receiver/processor12/constant/polyMesh" Writing boundaryProcAddressing to "receiver/processor12/constant/polyMesh" Reading processor 13 mesh from "receiver/processor13" Writing pointProcAddressing to "receiver/processor13/constant/polyMesh" Writing faceProcAddressing to "receiver/processor13/constant/polyMesh" Writing cellProcAddressing to "receiver/processor13/constant/polyMesh" Writing boundaryProcAddressing to "receiver/processor13/constant/polyMesh" Reading processor 14 mesh from "receiver/processor14" Writing pointProcAddressing to "receiver/processor14/constant/polyMesh" Writing faceProcAddressing to "receiver/processor14/constant/polyMesh" Writing cellProcAddressing to "receiver/processor14/constant/polyMesh" Writing boundaryProcAddressing to "receiver/processor14/constant/polyMesh" Reading processor 15 mesh from "receiver/processor15" Writing pointProcAddressing to "receiver/processor15/constant/polyMesh" Writing faceProcAddressing to "receiver/processor15/constant/polyMesh" Writing cellProcAddressing to "receiver/processor15/constant/polyMesh" Writing boundaryProcAddressing to "receiver/processor15/constant/polyMesh" End. parallels@ubuntu:~/OpenFOAM-2.4.0/receiver$ paraFoam created temporary 'receiver.OpenFOAM' parallels@ubuntu:~/OpenFOAM-2.4.0/receiver$ decomposePar /*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.4.0 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 2.4.0-f0842aea0e77 Exec : decomposePar Date : Oct 26 2015 Time : 10:35:43 Host : "ubuntu" PID : 1799 Case : /home/parallels/OpenFOAM-2.4.0/receiver nProcs : 1 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster allowSystemOperations : Allowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Decomposing mesh region0 Create mesh Calculating distribution of cells Selecting decompositionMethod hierarchical Finished decomposition in 39.32 s Calculating original mesh data Distributing cells to processors Distributing faces to processors Distributing points to processors Constructing processor meshes --> FOAM FATAL ERROR: Cell 0contains face labels out of range: 6(0 1 2 -1 -1 -1) Max face index = 3515586 From function polyMesh::polyMesh ( const IOobject&, const Xfer<pointField>&, const Xfer<faceList>&, const Xfer<cellList>& ) in file meshes/polyMesh/polyMesh.C at line 654. FOAM aborting #0 Foam::error::printStack(Foam::Ostream&) at ??:? #1 Foam::error::abort() at ??:? #2 Foam::polyMesh::polyMesh(Foam::IOobject const&, Foam::Xfer<Foam::Field<Foam::Vector<double> > > const&, Foam::Xfer<Foam::List<Foam::face> > const&, Foam::Xfer<Foam::List<Foam::cell> > const&, bool) at ??:? #3 ? at ??:? #4 ? at ??:? #5 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6" #6 ? at ??:? Aborted (core dumped) parallels@ubuntu:~/OpenFOAM-2.4.0/receiver$ |
October 29, 2015, 21:43 |
#25 |
nasir musa yakubu
Rep Power: 12 |
once again, i have achieved some progress by following your suggestion bruno: Code:
reconstructParMesh -latestTime -fullMatch Code:
reconstructParMesh -latestTime -mergeTol 1e-7 Code:
parallels@ubuntu:~/OpenFOAM-2.4.0/chtMRF$ decomposePar /*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.4.0 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 2.4.0-f0842aea0e77 Exec : decomposePar Date : Oct 30 2015 Time : 01:18:56 Host : "ubuntu" PID : 4201 Case : /home/parallels/OpenFOAM-2.4.0/chtMRF nProcs : 1 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster allowSystemOperations : Allowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Decomposing mesh region0 Create mesh Calculating distribution of cells Selecting decompositionMethod hierarchical Finished decomposition in 28.06 s Calculating original mesh data Distributing cells to processors Distributing faces to processors Distributing points to processors Constructing processor meshes Processor 0 Number of cells = 989712 Number of faces shared with processor 1 = 8538 Number of faces shared with processor 2 = 17864 Number of faces shared with processor 3 = 8 Number of faces shared with processor 8 = 8258 Number of faces shared with processor 10 = 148 Number of processor patches = 5 Number of processor faces = 34816 Number of boundary faces = 15701 Processor 1 Number of cells = 989712 Number of faces shared with processor 0 = 8538 Number of faces shared with processor 2 = 7 Number of faces shared with processor 3 = 17916 Number of faces shared with processor 8 = 51 Number of faces shared with processor 9 = 7647 Number of faces shared with processor 11 = 234 Number of processor patches = 6 Number of processor faces = 34393 Number of boundary faces = 10976 Processor 2 Number of cells = 989712 Number of faces shared with processor 0 = 17864 Number of faces shared with processor 1 = 7 Number of faces shared with processor 3 = 10387 Number of faces shared with processor 4 = 22340 Number of faces shared with processor 5 = 24 Number of faces shared with processor 10 = 9495 Number of faces shared with processor 11 = 1 Number of faces shared with processor 12 = 50 Number of processor patches = 8 Number of processor faces = 60168 Number of boundary faces = 3923 Processor 3 Number of cells = 989712 Number of faces shared with processor 0 = 8 Number of faces shared with processor 1 = 17916 Number of faces shared with processor 2 = 10387 Number of faces shared with processor 4 = 34 Number of faces shared with processor 5 = 24347 Number of faces shared with processor 10 = 26 Number of faces shared with processor 11 = 9202 Number of faces shared with processor 13 = 92 Number of processor patches = 8 Number of processor faces = 62012 Number of boundary faces = 2004 Processor 4 Number of cells = 989712 Number of faces shared with processor 2 = 22340 Number of faces shared with processor 3 = 34 Number of faces shared with processor 5 = 11365 Number of faces shared with processor 6 = 16067 Number of faces shared with processor 7 = 8 Number of faces shared with processor 10 = 2 Number of faces shared with processor 12 = 11131 Number of faces shared with processor 13 = 1 Number of processor patches = 8 Number of processor faces = 60948 Number of boundary faces = 356 Processor 5 Number of cells = 989712 Number of faces shared with processor 2 = 24 Number of faces shared with processor 3 = 24347 Number of faces shared with processor 4 = 11365 Number of faces shared with processor 6 = 31 Number of faces shared with processor 7 = 17102 Number of faces shared with processor 13 = 11081 Number of faces shared with processor 15 = 26 Number of processor patches = 7 Number of processor faces = 63976 Number of boundary faces = 227 Processor 6 Number of cells = 989713 Number of faces shared with processor 4 = 16067 Number of faces shared with processor 5 = 31 Number of faces shared with processor 7 = 18280 Number of faces shared with processor 12 = 89 Number of faces shared with processor 14 = 17730 Number of faces shared with processor 15 = 10 Number of processor patches = 6 Number of processor faces = 52207 Number of boundary faces = 222 Processor 7 Number of cells = 989712 Number of faces shared with processor 4 = 8 Number of faces shared with processor 5 = 17102 Number of faces shared with processor 6 = 18280 Number of faces shared with processor 13 = 8 Number of faces shared with processor 14 = 6 Number of faces shared with processor 15 = 17368 Number of processor patches = 6 Number of processor faces = 52772 Number of boundary faces = 224 Processor 8 Number of cells = 989712 Number of faces shared with processor 0 = 8258 Number of faces shared with processor 1 = 51 Number of faces shared with processor 9 = 8895 Number of faces shared with processor 10 = 22284 Number of processor patches = 4 Number of processor faces = 39488 Number of boundary faces = 10672 Processor 9 Number of cells = 989713 Number of faces shared with processor 1 = 7647 Number of faces shared with processor 8 = 8895 Number of faces shared with processor 10 = 102 Number of faces shared with processor 11 = 22931 Number of processor patches = 4 Number of processor faces = 39575 Number of boundary faces = 6377 Processor 10 Number of cells = 989712 Number of faces shared with processor 0 = 148 Number of faces shared with processor 2 = 9495 Number of faces shared with processor 3 = 26 Number of faces shared with processor 4 = 2 Number of faces shared with processor 8 = 22284 Number of faces shared with processor 9 = 102 Number of faces shared with processor 11 = 10446 Number of faces shared with processor 12 = 19771 Number of faces shared with processor 13 = 12 Number of processor patches = 9 Number of processor faces = 62286 Number of boundary faces = 2016 Processor 11 Number of cells = 989713 Number of faces shared with processor 1 = 234 Number of faces shared with processor 2 = 1 Number of faces shared with processor 3 = 9202 Number of faces shared with processor 9 = 22931 Number of faces shared with processor 10 = 10446 Number of faces shared with processor 12 = 24 Number of faces shared with processor 13 = 19779 Number of processor patches = 7 Number of processor faces = 62617 Number of boundary faces = 76 Processor 12 Number of cells = 989712 Number of faces shared with processor 2 = 50 Number of faces shared with processor 4 = 11131 Number of faces shared with processor 6 = 89 Number of faces shared with processor 10 = 19771 Number of faces shared with processor 11 = 24 Number of faces shared with processor 13 = 11381 Number of faces shared with processor 14 = 15590 Number of faces shared with processor 15 = 20 Number of processor patches = 8 Number of processor faces = 58056 Number of boundary faces = 215 Processor 13 Number of cells = 989713 Number of faces shared with processor 3 = 92 Number of faces shared with processor 4 = 1 Number of faces shared with processor 5 = 11081 Number of faces shared with processor 7 = 8 Number of faces shared with processor 10 = 12 Number of faces shared with processor 11 = 19779 Number of faces shared with processor 12 = 11381 Number of faces shared with processor 14 = 14 Number of faces shared with processor 15 = 15606 Number of processor patches = 9 Number of processor faces = 57974 Number of boundary faces = 78 Processor 14 Number of cells = 989714 Number of faces shared with processor 6 = 17730 Number of faces shared with processor 7 = 6 Number of faces shared with processor 12 = 15590 Number of faces shared with processor 13 = 14 Number of faces shared with processor 15 = 18275 Number of processor patches = 5 Number of processor faces = 51615 Number of boundary faces = 224 Processor 15 Number of cells = 989713 Number of faces shared with processor 5 = 26 Number of faces shared with processor 6 = 10 Number of faces shared with processor 7 = 17368 Number of faces shared with processor 12 = 20 Number of faces shared with processor 13 = 15606 Number of faces shared with processor 14 = 18275 Number of processor patches = 6 Number of processor faces = 51305 Number of boundary faces = 224 Number of processor faces = 422104 Max number of cells = 989714 (0.0001578741% above average 989712.4) Max number of processor patches = 9 (35.84906% above average 6.625) Max number of faces between processors = 63976 (21.25163% above average 52763) Time = 0 --> FOAM FATAL IO ERROR: Cannot find patchField entry for maxY file: /home/parallels/OpenFOAM-2.4.0/chtMRF/0/alphat.boundaryField from line 25 to line 126. From function GeometricField<Type, PatchField, GeoMesh>::GeometricBoundaryField::readField(const DimensionedField<Type, GeoMesh>&, const dictionary&) in file /home/openfoam/OpenFOAM/OpenFOAM-2.4.0/src/OpenFOAM/lnInclude/GeometricBoundaryField.C at line 209. FOAM exiting parallels@ubuntu:~/OpenFOAM-2.4.0/chtMRF$ Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.4.0 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class polyBoundaryMesh; location "0.003/polyMesh"; object boundary; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // 48 ( maxY { type wall; inGroups 1(wall); nFaces 262; startFace 49884400; } minX { type patch; nFaces 13784; startFace 49884662; } maxX { type patch; nFaces 437; startFace 49898446; } minY { type wall; inGroups 1(wall); nFaces 24709; startFace 49898883; } minZ { type wall; inGroups 1(wall); nFaces 13778; startFace 49923592; } maxZ { type wall; inGroups 1(wall); nFaces 545; startFace 49937370; } inlet { type wall; inGroups 1(wall); nFaces 0; startFace 49937915; } inlet_slave { type wall; inGroups 1(wall); nFaces 0; startFace 49937915; } outlet { type wall; inGroups 1(wall); nFaces 0; startFace 49937915; } outlet_slave { type wall; inGroups 1(wall); nFaces 0; startFace 49937915; } lens { type wall; inGroups 1(wall); nFaces 0; startFace 49937915; } lens_slave { type wall; inGroups 1(wall); nFaces 0; startFace 49937915; } bot { type wall; inGroups 1(wall); nFaces 0; startFace 49937915; } bot_slave { type wall; inGroups 1(wall); nFaces 0; startFace 49937915; } top { type wall; inGroups 1(wall); nFaces 0; startFace 49937915; } top_slave { type wall; inGroups 1(wall); nFaces 0; startFace 49937915; } s1 { type wall; inGroups 1(wall); nFaces 0; startFace 49937915; } s1_slave { type wall; inGroups 1(wall); nFaces 0; startFace 49937915; } s2 { type wall; inGroups 1(wall); nFaces 0; startFace 49937915; } s2_slave { type wall; inGroups 1(wall); nFaces 0; startFace 49937915; } s3 { type wall; inGroups 1(wall); nFaces 0; startFace 49937915; } s3_slave { type wall; inGroups 1(wall); nFaces 0; startFace 49937915; } s4 { type wall; inGroups 1(wall); nFaces 0; startFace 49937915; } s4_slave { type wall; inGroups 1(wall); nFaces 0; startFace 49937915; } s5 { type wall; inGroups 1(wall); nFaces 0; startFace 49937915; } s5_slave { type wall; inGroups 1(wall); nFaces 0; startFace 49937915; } s6 { type wall; inGroups 1(wall); nFaces 0; startFace 49937915; } s6_slave { type wall; inGroups 1(wall); nFaces 0; startFace 49937915; } s7 { type wall; inGroups 1(wall); nFaces 0; startFace 49937915; } s7_slave { type wall; inGroups 1(wall); nFaces 0; startFace 49937915; } s8 { type wall; inGroups 1(wall); nFaces 0; startFace 49937915; } s8_slave { type wall; inGroups 1(wall); nFaces 0; startFace 49937915; } s9 { type wall; inGroups 1(wall); nFaces 0; startFace 49937915; } s9_slave { type wall; inGroups 1(wall); nFaces 0; startFace 49937915; } s10 { type wall; inGroups 1(wall); nFaces 0; startFace 49937915; } s10_slave { type wall; inGroups 1(wall); nFaces 0; startFace 49937915; } s11 { type wall; inGroups 1(wall); nFaces 0; startFace 49937915; } s11_slave { type wall; inGroups 1(wall); nFaces 0; startFace 49937915; } s12 { type wall; inGroups 1(wall); nFaces 0; startFace 49937915; } s12_slave { type wall; inGroups 1(wall); nFaces 0; startFace 49937915; } s13 { type wall; inGroups 1(wall); nFaces 0; startFace 49937915; } s13_slave { type wall; inGroups 1(wall); nFaces 0; startFace 49937915; } s14 { type wall; inGroups 1(wall); nFaces 0; startFace 49937915; } s14_slave { type wall; inGroups 1(wall); nFaces 0; startFace 49937915; } s15 { type wall; inGroups 1(wall); nFaces 0; startFace 49937915; } s15_slave { type wall; inGroups 1(wall); nFaces 0; startFace 49937915; } insulator { type wall; inGroups 1(wall); nFaces 0; startFace 49937915; } insulator_slave { type wall; inGroups 1(wall); nFaces 0; startFace 49937915; } ) // ************************************************************************* // |
October 31, 2015, 10:54 |
#26 |
Bruno Santos
Rep Power: 128 |
Hi Nasir,
Details, details, details... OpenFOAM is all about the details The first detail that you didn't describe is how exactly you were running snappyHexMesh. The original problem would have been solved if you had executed with the "-overwrite" option, for example: Code:
snappyHexMesh -overwrite
Best regards, Bruno |
November 1, 2015, 18:24 |
#27 |
nasir musa yakubu
Rep Power: 12 |
Hello Bruno,
Thanks for your reply, i have actually resolved the issue, it wasn't the method i was using to run snappyHexMesh, i have tried the overwrite option already but i think it can be used to resolve similar issue. I deleted the boundary patches in all the files located in the 0 folder that was why, using wildcat option resolved the issue e.g: Code:
// * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [1 -1 -1 0 0 0 0]; internalField uniform 0; boundaryField { ".*" { type calculated; value uniform 0; } } // ************************************************************************* // However, I am currently facing a new problem which i guess i ve found a solution but i just want some clarifications. my CAD model is an assembly, with each part/region in a separate still file. I followed this procedure: Code:
---------------------------------------------------------------------- Rename 0 folder 0.org This prevents SHMesh interfering with it < blockMesh > Creates background mesh for SHMesh < surfaceFeatureExtract > So the mesher knows where to snap to < decomposePar > Divides mesh into one section per CPU core < mpirun -np 16 snappyHexMesh -overwrite -parallel > Runs mesher in parallel < < reconstructParMesh -latestTime -fullMatch 7 delete all processor folders Clear old mesh data 8 delete folder 0 This was a dummy folder for SHMesh 9 rename folder 0.org to 0 Reactivate the folder for the solver to use ---------------------- ------------------------------------------------- 10 edit the constant/polymesh/boundary file and remove all the references to patches created by blockMesh in Step2. Le§ave only the patches desired for the simulation to run. Edit the number at the top of the text file which shows how many patches are to be setup. ----------------------------------------------------------------------- 11 < decomposePar > Puts the solution setup into a folder per CPU core 12 <mpirun -n 16 renumberMesh -overwrite -parallel> Optimises the mesh ----------------------------------------------------------------------- 13 <mpirun -np 16 chtMultiRegionFoam -parallel> Run the solver in parallel Code:
splitMeshRegions -cellZones thanks |
November 2, 2015, 18:04 |
#28 | |
Bruno Santos
Rep Power: 128 |
The command splitMeshRegions is for splitting parts of the mesh into independent regions. But the problem is that your mesh is incorrectly created. You need to first diagnose the problems you have in using snappyHexMesh. For more details: http://openfoamwiki.net/index.php/SnappyHexMesh |
May 7, 2017, 17:01 |
#29 | |
Syed M. Usama
Rep Power: 10 |
August 23, 2017, 14:17 |
#30 |
Limone
Rep Power: 9 |
Dear All,
I have the same error message Code:
Cell 0contains face labels out of range: 6(0 1 2 -1 -1 -1) After the following procedure (via terminal): Code:
1 Rename 0 folder 0.org 2 < blockMesh > 3 < surfaceFeatureExtract > 4 < decomposePar > 5 < mpirun -np 4 snappyHexMesh -overwrite -parallel > 6 < reconstructParMesh -constant -fullMatch > 7 delete all processor folders 8 delete folder 0 9 rename folder 0.org to 0 10 edit the constant/polymesh/boundary file and remove all the references to patches created by blockMesh in Step2. Leave only the patches desired for the simulation to run. Edit the number at the top of the text file which shows how many patches are to be setup. 11 < decomposePar > Code:
/*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 3.0.x | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 3.0.x-ac3f6c67e02f Exec : decomposePar Date : Aug 23 2017 Time : 18:33:46 Host : "rbalwmba80000.bas.roche.com" PID : 27296 Case : /home/cfdemuser/CFDEM/CFDEMcoupling-PUBLIC-3.0.x/tutorials_LORETI/cfdemSolverPiso/ErgunTestMPI2b/CFD nProcs : 1 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster allowSystemOperations : Allowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Decomposing mesh region0 Create mesh Calculating distribution of cells Selecting decompositionMethod simple Finished decomposition in 3.31 s Calculating original mesh data Distributing cells to processors Distributing faces to processors Distributing points to processors Constructing processor meshes --> FOAM FATAL ERROR: Cell 0contains face labels out of range: 6(0 1 2 -1 -1 -1) Max face index = 3526636 From function polyMesh::polyMesh ( const IOobject&, const Xfer<pointField>&, const Xfer<faceList>&, const Xfer<cellList>& ) in file meshes/polyMesh/polyMesh.C at line 654. FOAM aborting #0 Foam::error::printStack(Foam::Ostream&) at ??:? #1 Foam::error::abort() at ??:? #2 Foam::polyMesh::polyMesh(Foam::IOobject const&, Foam::Xfer<Foam::Field<Foam::Vector<double> > > const&, Foam::Xfer<Foam::List<Foam::face> > const&, Foam::Xfer<Foam::List<Foam::cell> > const&, bool) at ??:? #3 ? at ??:? #4 ? at ??:? #5 __libc_start_main in "/lib64/libc.so.6" #6 ? at ??:? Aborted (core dumped) Code:
/*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 3.0.x | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 3.0.x-ac3f6c67e02f Exec : checkMesh -allGeometry -allTopology Date : Aug 23 2017 Time : 18:50:33 Host : "rbalwmba80000.bas.roche.com" PID : 29055 Case : /home/cfdemuser/CFDEM/CFDEMcoupling-PUBLIC-3.0.x/tutorials_LORETI/cfdemSolverPiso/ErgunTestMPI2b/CFD nProcs : 1 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster allowSystemOperations : Allowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create polyMesh for time = 0 Enabling all (cell, face, edge, point) topology checks. Enabling all geometry checks. Time = 0 Mesh stats points: 5158977 faces: 14082002 internal faces: 13488393 cells: 4502214 faces per cell: 6.12374 boundary patches: 3 point zones: 0 face zones: 0 cell zones: 0 Overall number of cells of each type: hexahedra: 3904264 prisms: 163980 wedges: 0 pyramids: 0 tet wedges: 485 tetrahedra: 0 polyhedra: 433485 Breakdown of polyhedra by number of faces: faces number of cells 4 77048 5 56483 6 53872 7 628 8 130 9 186034 12 53320 15 5970 Checking topology... ****Problem with boundary patch 0 named wall of type wall. The patch should start on face no 13488393 and the patch specifies 13503393. Possibly consecutive patches have this same problem. Suppressing future warnings. ***Boundary definition is in error. Cell to face addressing OK. Point usage OK. Upper triangular ordering OK. Face vertices OK. Topological cell zip-up check OK. <<Number of faces with non-consecutive shared points: 11. This might indicate a problem. <<Writing 14 faces with non-standard edge connectivity to set edgeFaces Number of regions: 1 (OK). Checking patch topology for multiply connected surfaces... Patch Faces Points Surface topology Bounding box wall 553691 635169 ok (non-closed singly connected) (-0.0979907 -0.0979912 -6.86046e-09) (0.0980502 0.0979865 0.565054) inlet 5918 6908 ok (non-closed singly connected) (-0.0419709 -0.04207 -9.2327e-07) (0.0421114 0.0419902 0.00074498) outlet 19000 21379 ok (non-closed singly connected) (-0.0977539 -0.0974848 0.563514) (0.0979553 0.0976161 0.565111) Checking geometry... Overall domain bounding box (-0.12 -0.12 -0.05) (0.12 0.12 0.65) Mesh has 3 geometric (non-empty/wedge) directions (1 1 1) Mesh has 3 solution (non-empty) directions (1 1 1) Boundary openness (3.90822e-16 4.03493e-17 -6.0453e-17) OK. Max cell openness = 4.9229e-16 OK. Max aspect ratio = 25.5492 OK. Minimum face area = 4.12223e-08. Maximum face area = 7.93287e-05. Face area magnitudes OK. Min volume = 1.97545e-11. Max volume = 3.82669e-07. Total volume = 0.0403192. Cell volumes OK. Mesh non-orthogonality Max: 65 average: 15.041 Non-orthogonality check OK. Face pyramids OK. ***Max skewness = 4.47871, 7 highly skew faces detected which may impair the quality of the results <<Writing 7 skew faces to set skewFaces Coupled point location match (average 0) OK. #0 Foam::error::printStack(Foam::Ostream&) at ??:? #1 Foam::sigSegv::sigHandler(int) at ??:? #2 ? in "/lib64/libc.so.6" #3 Foam::polyMeshTetDecomposition::checkFaceTets(Foam::polyMesh const&, double, bool, Foam::HashSet<int, Foam::Hash<int> >*) at ??:? #4 ? at ??:? #5 ? at ??:? #6 __libc_start_main in "/lib64/libc.so.6" #7 ? at ??:? Segmentation fault (core dumped) It is a long time that I am trying to solve this problem and I am out of ideas. Any suggestion ?? Best, Limone |
February 7, 2018, 06:24 |
#31 | |
Rep Power: 8 |
Faced this problem too. I solved it by skipping the step to delete the background mesh created by BlockMesh
February 7, 2018, 06:41 |
#32 |
Tobias Holzmann
Rep Power: 52 |
Hi, you should know what you do and not believe that things work fine while doing some things you cannot argue ... however, the topic is almost half a year old. So there is no need to bring it back while giving a vague feedback. By the way, welcome to the community.
Keep foaming, Tobias Holzmann |
February 7, 2018, 09:26 |
#33 |
Rep Power: 8 |
Sorry for my uncertain suggestion. Thanks a lot for your advice. I should have understood everything I did before suggests it to others. I need to learn a lot from members here. Thanks again
July 20, 2020, 04:32 |
#34 |
I just fixed a problem that showed up with similar error message during decomposePar.
After running 'checkMesh -allTopology -allGeometry', it turns out that I had deleted one patch in constant/polyMesh/boundary that came from the blockMeshDict, as advised in Callum Douglas' Youtube video on snappyHexMesh. It turns out that the STL geometry has slightly exceeded the blockMeshDict's bounding box, due to editing the geometry in the CAD tool. All went well after the vertices' coordinates specified in blockMeshDict were amended to fully enclose the STL geometry. Lesson: if the constant/polyMesh/boundary has a patch that comes from the block mesh, it's likely the bounding box is too small for the STL geometry and needs moving the offending plane outwards in blockMeshDict. |
July 20, 2020, 04:42 |
#35 |
Tobias Holzmann
Rep Power: 52 |
Hi, this is a well-known topic and obvious in terms of geometrical behavior. How should snappyHexMesh be aware of patches that are excluded from the background mesh? The background mesh should consist of pure cubes and should always enclose the geometry. Therefore, if one creates a bounding box with the exact points of the geometry, it is always nice to enlarge the background mesh a bit. E.g., by a factor of 1.1 or 1.001 (depending on your dimensions).
Tobi
July 20, 2020, 05:04 |
#36 |
I didn't mean to say that snappyHexMesh is supposed to be aware of the STL geometry protruding outside the bounding box. The message was merely to set out one case where the decomposePar error message giving a '-1' for geometry object index, so that others may become aware.
But, of course, now that you brought it up, seems obvious that snappyHexMesh could check. It has all the geometrical information after all. That's why tools have warnings and error messages, right? |
July 20, 2020, 05:07 |
#37 |
Tobias Holzmann
Rep Power: 52 |
Snappy will not give you an error if the background mesh does not fit the whole geometry as there are scenarios in which we want to have it like that. As you already pointed out, snappy will give the name of the patch coming from the background mesh. However, I am not sure why you get problems during decomposing. The only thing that occurs is, that you might not specified the (unwanted) patch in the boundary conditions and that's why decomposePar will give an error during the field decomposition. Or maybe I did not get the point here » this happens more often.
July 20, 2020, 06:38 |
#38 |
Precisely, "it turns out that I had deleted one patch in constant/polyMesh/boundary that came from the blockMeshDict, as advised in Callum Douglas' Youtube video on snappyHexMesh" is what caused my decomposePar error, which led me to discover that my revised STL geometry protruded outside the original bounding box ever so slightly.
[ICEM] Error in mesh writing | helios | ANSYS Meshing & Geometry | 21 | August 19, 2021 15:18 |
FvMatrix coefficients | shrina | OpenFOAM Running, Solving & CFD | 10 | October 3, 2013 15:38 |
Error message: 8 face(s) not in face lists of adjacent cells | jyoung79 | FLUENT | 0 | November 10, 2012 17:09 |
[blockMesh] error message with modeling a cube with a hold at the center | hsingtzu | OpenFOAM Meshing & Mesh Conversion | 2 | March 14, 2012 10:56 |
how to access each cell of a face? (user fortran) | Katariina | CFX | 3 | January 28, 2008 10:16 |
