k-epsilon model in the airfoil example-simplefoam
Old   November 30, 2014, 19:10
Default k-epsilon model in the airfoil example-simplefoam
tareqkh's Avatar
CFD
tareqkh is on a distinguished road
Hey Foamers,
I hope that you are all enjoying the forum and the cfd world. I am new about using openfoam. My first example was about the cavity example. I followed the steps as it is written on the openFoam website. I successfully got the results about it. Currently, I am working on the air-foil example using simplefoam. In this example, I obtained both the lift and drag forces by implementing a special file in the system folder. The second step was about getting the monitor convergence in which I implemented a script file with the Allclean and Allrun. I obtained the residual and the no of iterations for the velocity and pressure.
I just need to know how to implement the k-epsilon turbulence mode in this example since it already works with Spalart-Allmaras.
Kind regards,
tareqkh is offline   Reply With Quote
Old   November 30, 2014, 23:53
tareqkh's Avatar
CFD
Hey Foamers,
I have executed the 2D airfoil example that is provided with simple-foam. I used the SpalartAllmaras turbulence model since it is the default turbulence model.
I want to switch to the k-epsilon turbulence model. I have searched the forums and have not found a simpleFoam case with k-epsilon model.
Would someone please upload a 2D converged simpleFoam case which has the k-epsilon turbulence model implemented. I want to study how the fvScheme and fvSolution files are set up and how they differ from my k-epsilon case.
Regards,
Old   December 1, 2014, 20:35
tareqkh's Avatar
CFD
Anybody who is willing to help?
Problem with airfoil shape optimization robyTKD SU2 Shape Design 7 March 7, 2022 17:18
SimpleFoam case with SpalartAllmaras turbulence model implemented nedved OpenFOAM Running, Solving & CFD 2 November 30, 2014 23:43
Problem with restart solution in shape_optimization.py robyTKD SU2 Shape Design 21 May 29, 2013 10:26
Problem running simpleFoam on a multi element airfoil vinz OpenFOAM Running, Solving & CFD 18 April 11, 2013 12:26
RANS-Sim. of airfoil: inlet condition of epsilon? Norman Cook Main CFD Forum 3 November 19, 2006 12:30
