BC for Internal Walls
Old   November 13, 2014, 10:56
Default BC for Internal Walls
Anonymous
s.tilt is on a distinguished road
Hi Everyone,
I am wondering how I would go about putting a boundary condition on an internal wall. The idea is to close off two faces (set two faces as a wall) so that water does not flow through those faces. I have been reading posts and think that I can use topoSet and then createBaffles. Is this the right procedure? How exactly would I go about this? I am new to openFoam and still learning, any help would be greatly appreciated !
Thanks,
S
I've attached my mesh and a drawing of my mesh, with the faces I want to make walls in red ink.
File Type: jpg Screenshot from 2014-11-13 10_47_01.jpg (65.6 KB, 16 views)
s.tilt is offline   Reply With Quote
Old   November 13, 2014, 15:25
Anonymous
I've attached my blockMesh, topoSetDict, and createBaffles files and the error that I am getting after the createBaffles. However, it allows me to use the interFoam solver, but then when I go to view the simulation using paraView paraView shuts down and I get the paraFoam error. Any help would be greatly appreciated!
Thanks,
S
[Gmsh] Boundary Layer Mesh in GMSH Medu OpenFOAM Meshing & Mesh Conversion 1 September 1, 2021 04:43
[ICEM] Shadow walls in Fluent. ICEM meshes vs Workbench aarvay ANSYS Meshing & Geometry 11 January 12, 2017 13:51
Enforce bounds error with heat loss boundary condition at solid walls Chander CFX 2 May 1, 2012 21:11
Problem with rhoSimpleFoam : exploding enthalpy and density at the walls david39 OpenFOAM Running, Solving & CFD 6 January 18, 2011 12:49
thermal conditions of walls Stefan FLUENT 2 March 23, 2003 07:17
