foam-extend 3.1 - mixingPlane interface definition
Old   October 16, 2014, 10:40
Default foam-extend 3.1 - mixingPlane interface definition
Yanyan Huang
yanyanh is on a distinguished road
Hi guys,
I'm doing a simulation of two counter-rotation propellers with different simulation approaches. The sliding mesh simulation using pimplyDyMFoam worked well, but what I need is a steady-state solution now.
Therefore, I'm using two MRF for the two propellers. Everything went well in OpenFOAM 2.3.0, but for the mixingPlane I had to switch to foam-extend 3.1.
In foam-extend 3.1 snappyHexMesh is not generating a master and a slave boundary anymore. Since there is no topoSet and createBaffles like in OF-2.3, how can I generate an interface with a master and a slave patch?
I tried createPatch ans setSet but it wasn't successful. I would really appreciated your help!
Cheers,
Yanyan
yanyanh is offline   Reply With Quote
Old   March 12, 2015, 06:20
M. Montero
be_inspired is on a distinguished road
I am quite interested in this topic. Did you solve your simulation into OF3.1-ext?
be_inspired is offline   Reply With Quote
Old   June 19, 2015, 05:34
deepinheart is on a distinguished road
Originally Posted by yanyanh View Post
Hi guys,
Cheers,
Yanyan
I have the same problem. May I know how you deal with that?
Thanks!
deepinheart is offline   Reply With Quote
Old   June 19, 2015, 05:44
Default mixing plane implementation
Yanyan Huang
Hi, I did a workaround where I used the steadystate solution of the first rotor and circumferentially averaged the results using rotating the mesh by different angles and averaging over these fields. Then I mapped the circumferential averaged field onto the second model with the second rotor. I know, not a elegant solution but it worked well for me.
Don't hesitate to ask .
Cheers
Old   June 19, 2015, 06:07
Thanks!
I have to use topoSet in OF ext 3.1 and there is no way to have a workaround in my case. Try to compile topoSet individually but failed.
foam-extend-3.1, interface, master, mixingplane, slave
whats the cause of error? immortality OpenFOAM Running, Solving & CFD 13 March 24, 2021 08:15
channelFoam for a 3D pipe AlmostSurelyRob OpenFOAM 3 June 24, 2011 14:06
[Gmsh] Import gmsh msh to Foam adorean OpenFOAM Meshing & Mesh Conversion 24 April 27, 2005 09:19
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 16:55
Replace periodic by inlet-outlet pair lego CFX 3 November 5, 2002 21:09
