mapFields Error with snappyHexMesh Source Added Layers |
AI
Rep Power: 12 ![]() |
I get the error below when I try to mapFields from coarser mesh to finer mesh. I know what causes the issue but I don't know how to resolve it.
The source mesh was created using blockMesh and then I use " snappyHexMesh -overwrite" addLayers option to add some BL cells around the body surface. Which changes the source mesh size from 331200 to 358080. The problem is mapFields reads the source original (before snappy) mesh size and stops when starts reading the source data fields which have data for 358080 cells. The strange thing is that mapFields reads the target final mesh size (after snappy). Does anyone knows how to correct this issue? Thank you. The error: Create databases as time Case : ../103_30_12w_08_3d_8 nProcs : 1 Source time: 40 Target time: 40 Create meshes Source mesh size: 331200 Target mesh size: 457120 Consistently creating and mapping fields for time 40 Creating mesh-to-mesh addressing for region0 and region0 regions using cellVolumeWeight Overlap volume: 3352.14646954 Creating AMI between source patch cylinder and target patch cylinder using faceAreaWeightAMI AMI: Creating addressing and weights between 1920 source faces and 2560 target faces AMI: Patch source sum(weights) min/max/average = 1.00002409633, 1.00003212822, 1.00002677363 AMI: Patch target sum(weights) min/max/average = 1, 1.00002855847, 1.00001427923 Creating AMI between source patch inlet and target patch inlet using faceAreaWeightAMI AMI: Creating addressing and weights between 960 source faces and 1120 target faces AMI: Patch source sum(weights) min/max/average = 1, 1, 1 AMI: Patch target sum(weights) min/max/average = 1, 1, 1 Creating AMI between source patch outlet and target patch outlet using faceAreaWeightAMI AMI: Creating addressing and weights between 960 source faces and 1120 target faces AMI: Patch source sum(weights) min/max/average = 1, 1, 1 AMI: Patch target sum(weights) min/max/average = 1, 1, 1 Creating AMI between source patch sideWall_1 and target patch sideWall_1 using faceAreaWeightAMI AMI: Creating addressing and weights between 2520 source faces and 2680 target faces AMI: Patch source sum(weights) min/max/average = 1, 1, 1 AMI: Patch target sum(weights) min/max/average = 1, 1, 1 Creating AMI between source patch sideWall_2 and target patch sideWall_2 using faceAreaWeightAMI AMI: Creating addressing and weights between 2520 source faces and 2680 target faces AMI: Patch source sum(weights) min/max/average = 1, 1, 1 AMI: Patch target sum(weights) min/max/average = 1, 1, 1 interpolating k_0 --> FOAM FATAL IO ERROR: size 358080 is not equal to the given value of 331200 file: ../103_30_12w_08_3d_8/40/k_0 from line 18 to line 54. From function Field<Type>::Field(const word& keyword, const dictionary&, const label) in file /home/sergio/rpmbuild/BUILD/OpenFOAM-2.3.0/src/OpenFOAM/lnInclude/Field.C at line 292. FOAM exiting |
[Other] OpenFOAM Installation for navalFoam | sachinlb | OpenFOAM Community Contributions | 22 | July 28, 2017 05:26 |
[snappyHexMesh] Adding layers goes wrong with SnappyHexMesh | Elise | OpenFOAM Meshing & Mesh Conversion | 1 | April 22, 2013 02:32 |
UDF Scalar Code: HT 1 | Greg Perkins | FLUENT | 8 | October 20, 2000 12:40 |
UDFs for Scalar Eqn - Fluid/Solid HT | Greg Perkins | FLUENT | 0 | October 13, 2000 23:03 |
UDFs for Scalar Eqn - Fluid/Solid HT | Greg Perkins | FLUENT | 0 | October 11, 2000 03:43 |
