How to setup initial pressure for an ABL buoyantBoussinesqSimpleFoam simulation |
September 24, 2014, 09:27 |
Leonardo Oliveira
Rep Power: 12 |
Hello Foamers,
I have started to use OpenFOAM this year, and right now I'm trying to use it to perform an ABL simulation considering the temperature effects, so a decide to use the buoyantBoussinesqSimpleFoam solver. The simulation consists in a flat terrain with a Box in the middle, the top BC is 310K hot and the rest (inlet, outlet, sides, ground and Box) is 283k. The U in the inlet is a log prifile made with the ABLconditions file (took from the turbineSiting tutorial). When I start the solver it start the calculations but, for some reason that I don't know, the time step continuity errors goes up high and the simulation stops with a "floating point exception". I think this has to be with the BC (correct me if I'm wrong). So I have some questions: 1. How am i supose to setup the initial "p_rgh" file? 2. The "p" file is really needed? Thanks in advance. Sorry for the bad English. Leonardo Oliveira. |
November 20, 2014, 12:17 |
Could you solve the problem? I have the same problems.
abl flow, buoyantboussinesqsf, p_rgh, temperature bc |
Extrusion with OpenFoam problem No. Iterations 0 | Lord Kelvin | OpenFOAM Running, Solving & CFD | 8 | March 28, 2016 12:08 |
Micro Scale Pore, icoFoam | gooya_kabir | OpenFOAM Running, Solving & CFD | 2 | November 2, 2013 14:58 |
How to write k and epsilon before the abnormal end | xiuying | OpenFOAM Running, Solving & CFD | 8 | August 27, 2013 16:33 |
Error while running rhoPisoFoam.. | nileshjrane | OpenFOAM Running, Solving & CFD | 8 | August 26, 2010 13:50 |
Problems with simulating TurbFOAM | barath.ezhilan | OpenFOAM | 13 | July 16, 2009 06:55 |
