Pressure BC using interFoam
Old   September 23, 2014, 13:36
Default Pressure BC using interFoam
Anonymous
s.tilt is on a distinguished road
Hi Everyone,
I am very new to OpenFOAM and am trying to simulate water entering a tank (very similar to this bottle filling tutorial: http://www.tfd.chalmers.se/~hani/kur...Hemida_VOF.pdf).
My mesh works fine, and is attached for reference. The problem I am having is with the Pressure boundary conditions. I've attached the pressure boundary conditions and velocity boundary conditions for reference.
The tank is originally filled with air and at time 0 water starts entering the tank through an inlet at the top. This is all based on the force of gravity which I have set up in the constant subfolder. I want to change the pressure at the inlet and see how this affects the water entering the tank. Right now the pressure at the inlet is set to fixedFluxPressure uniform 0. When I change the zero to different values I see no difference in the water falling from the inlet. Am I using the proper boundary condition here?
s.tilt is offline   Reply With Quote
Old   October 5, 2014, 21:10
zandi's Avatar
Fatema Zandi Goharrizi
zandi is on a distinguished road
Hi
fixedFluxPressure is a derived BC from zeroGradient type which can changed to a value in agreement with calculated U domain. it helps in better convergence.
test totalPressure for P inlet and pressureInletVelocity for U inlet if you have the value of pressure at inlet, and see what happen then.
zandi is offline   Reply With Quote
Old   October 6, 2014, 14:11
Anonymous
Thanks for answering! It won't let me change P inlet to totalPressure with the atmosphere set to totalPressure. Do I just have to change the variables for P inlet?
Thanks
Old   October 10, 2014, 17:05
zandi's Avatar
Hi tilt,
you're right. I had a wrong image in my mind from your geometry. i'm interested in your question, in my especial case about BC affects. I do free surface and interaction of air and water in flow. so if I find something helpful I would let you know.
could you attach an image from geometry?
and aaa
please let us have your useful experience in thread. kind of you foamer!
Old   October 14, 2014, 09:04
Anonymous
I've attached an image of the geometry and a new BlockMeshDict.
Still trying to solve my problem. If I solve the problem I will let you know.
File Type: jpg Screenshot from 2014-10-14 08_59_41.jpg (31.4 KB, 28 views)
boundary condition, inlet pressure, interfoam
pressure driven flow in interFoam deniggo OpenFOAM Running, Solving & CFD 28 November 18, 2015 09:54
Calculation of the Governing Equations Mihail CFX 7 September 7, 2014 07:27
strange pressure behaviour with symmetricPlane boudary condition - interFoam duongquaphim OpenFOAM Running, Solving & CFD 10 August 20, 2013 15:00
Pressure reference in cyclic interFoam AlmostSurelyRob OpenFOAM 7 February 16, 2011 10:58
interFoam pressure conservation AndrewB OpenFOAM 0 August 27, 2009 00:15
