Decomposing meshes
Like Tree14Likes
Old   October 1, 2021, 11:51
Raj Viren Lakhani
Rajl is on a distinguished road
Originally Posted by GerhardHolzinger View Post
Let me share a recent observation of mine.
I simulated axi-symmetric gas flow in a long pipe. As the domain is quite large, the simulation was run using several parallel processes. The scotch decomposition created a processor boundary, which zic-zags through the pipe.
The part of the processor boundary, which is parallel to the flow, seems to create some disturbance in the pressure field. Luckily, the disturbance does not blow up the simulation, yet it's quite interesting.
The attached images show the pressure field. The involved subdomains are shown as white wireframes.
Hi.. Were yoou able to eliminate the zig zags in the parallel subdomains?
Rajl is offline   Reply With Quote
Old   December 19, 2022, 14:35
Nidal
Nidalsb is on a distinguished road
Hello Tobi,
Have you found a solution to this? I have been struggling with this issue lately with 2 cyclic pairs in my simulation. Running in series gives me completely different results for Pressure in only the Z direction, the x and y directions are the completely unchanged though. very confusing. Tried different methods of decomposition and nothing seems to help
Nidalsb is offline   Reply With Quote
Old   February 24, 2023, 10:23
Default Problem In Mesh Decomposition
  #23
Peyman Haghighi
Peyman Haghighi is on a distinguished road
Dear Friends,
I want to decompose a mesh using DecomposePar command in OpenFOAM-7 along a single axis(for example z axis). However, I want the computational boundary cells of each part to be on a single plate(top and bottom plates' cells have a fixed z value)...If any one helps me in doing so, I will be more than happy...
The picture of the decomposed mesh applying simple algorithm is attached to this post...In this figure you can easily observe the problem I am dealing with...
Bests.
Peyman Haghighi is offline   Reply With Quote
Hex and Tet meshes - simplefoam comparison danvica OpenFOAM Running, Solving & CFD 10 January 4, 2013 02:18
Getting prism to inflate into mixed tet-hex meshes Joe CFX 16 October 10, 2011 08:06
HELP!! How could I obtain structured-orthogonal-body fitted meshes???? DajeMoo ANSYS 0 January 28, 2011 13:52
Dynamic Meshes Cfdtoy FLUENT 2 February 6, 2004 13:14
Large 3D tetrahedral meshes Aldo Bonfiglioli Main CFD Forum 4 August 27, 1999 04:33
