Diverging Courant number with interFoam case.
Old   August 10, 2014, 20:19
Default Diverging Courant number with interFoam case.
Edgar Fonseca
edgardfr is on a distinguished road
I have been using OpenFoam to simulate the filling phase in injection molding.
I began with the damBreak tutorial case and then I changed the mesh and the boundary conditions.
I am using as BC:
Inlet:
U--> fixedValue
value uniform (0 0 "velocity")
p--> zeroGradient
alpha--> fixedValue
uniform 1
Walls
U--> fixedValue
uniform (0 0 0)
p--> zeroGradient
alpha --> zeroGradient
Outlet
U--> zeroGradient
p-->fixedValue
uniform 0
alpha--> zeroGradient
My problem is that the Courant number increases with each step until it reaches the order of 10^50 or greater. If I set the adjustTimeStep , I find this: " Increased the timePrecision from 10 to 11 to distinguish between timeNames at time 5.97756e-10" and the solver get stuck increasing the precission of the timestep forever.
I even tried to set the inlet velocity as 0 ( if everything else was Ok, with an U=(0,0,0) the courant number should be 0). But the result was no different.
I also tried laminar, kepsilon and kOmegaSST for the turbulence model. The same problem.
I think it has something to do with the fvSchemes or fvSolution dictionaries but I don't know really how to check those files.
Any thoughts?
fvSolution dictionary.
solvers
"alpha.plastic.*"
nAlphaCorr 2;
nAlphaSubCycles 1;
cAlpha 1;
MULESCorr yes;
nLimiterIter 3;
solver smoothSolver;
smoother symGaussSeidel;
tolerance 1e-8;
relTol 0;
pcorr
solver PCG;
preconditioner DIC;
tolerance 1e-5;
relTol 0;
p_rgh
solver PCG;
preconditioner DIC;
tolerance 1e-07;
relTol 0.05;
p_rghFinal
$p_rgh;
tolerance 5e-9;
relTol 0;
"(U|k|epsilon).*"
tolerance 1e-06;
relTol 0;
minIter 1;
PIMPLE
momentumPredictor no;
nOuterCorrectors 1;
nCorrectors 3;
nNonOrthogonalCorrectors 0;
relaxationFactors
fields
equations
".*" 1;
fvSchemes dictionary
dtSchemes
default Euler;
gradSchemes
default Gauss;
divSchemes
default none;
div(rhoPhi,U) Gauss linearUpwind grad(U);
div(phi,alpha) Gauss vanLeer;
div(phirb,alpha) Gauss linear;
div(phi,k) Gauss upwind;
div(phi,epsilon) Gauss upwind;
div((muEff*dev(T(grad(U))))) Gauss linear;
laplacianSchemes
default Gauss linear corrected;
interpolationSchemes
default linear;
snGradSchemes
default corrected;
fluxRequired
default no;
p_rgh;
pcorr;
alpha.plastic;
edgardfr is offline   Reply With Quote
Old   August 18, 2014, 05:41
Jens Höpken
jhoepken is on a distinguished road
Send a message via Skype™ to jhoepken
Have you checked your mesh? What does checkMesh say?
Blog: sourceflux.de/blog
"The OpenFOAM Technology Primer": sourceflux.de/book
Twitter: @sourceflux_de
Interested in courses on OpenFOAM?
jhoepken is offline   Reply With Quote
Old   August 18, 2014, 06:33
Bernhard
Bernhard is on a distinguished road
Also, show relevant bits of your log file (way before Courant reaches 10^50)
Bernhard is offline   Reply With Quote
Old   August 18, 2014, 13:40
Default Solved
Edgar Fonseca
It was the mesh indeed, I ran the checkMesh and improved the mesh until it worked.
Thanks
Old   August 19, 2014, 05:12
Jens Höpken
Great! If in doubt - check the mesh
convergence, courant number, fvschemes, fvsolution, openfoam
Erroneous Courant Number in FOAM log? cwang5 OpenFOAM Running, Solving & CFD 0 April 29, 2014 23:45
Global Courant number diverging The_Architect FLUENT 3 August 29, 2011 03:22
DecomposePar unequal number of shared faces maka OpenFOAM Pre-Processing 6 August 12, 2010 10:01
Unaligned accesses on IA64 andre OpenFOAM 5 June 23, 2008 11:37
Free surface boudary conditions with SOLA-VOF Fan Main CFD Forum 10 September 9, 2006 13:24
