Help on values of k and epsilon for the k-epsilon equation
Old   July 31, 2014, 09:02
Unhappy Help on values of k and epsilon for the k-epsilon equation
Gaurav Shenoy
gauravshenoy is on a distinguished road
Send a message via Skype™ to gauravshenoy
I am having a bit of trouble with arriving at the values for k and epsilon for a problem.
The problem is a multiphase type, air and water (50-50) flowing at U = 1 m/s, across a 0.5m x 0.5m square closed channel over a length of 20m (i.e. inlet and outlet is separated by a 20m distance).
The problem is a 2D type so I've kept a front and back patch of empty type.
  • How do I arrive at the turbulent length scale for this problem?
  • Also, how do I calculate the values of k and epsilon at the walls and at the inlet/outlet?
I've referred to a lot of material on the web and on the books but I'm failing to understand how to arrive at l, k and epsilon for the inlet/outlet and the walls. Please help!
gauravshenoy is offline   Reply With Quote
dissipation rate, k-epsilon model, turbulent kinetic energy, turbulent length scale
SimpleFoam k and epsilon bounded nedved OpenFOAM Running, Solving & CFD 16 March 4, 2017 09:30
How to? Extra term in k-e equation. Implicit-Explicit be_inspired OpenFOAM Programming & Development 1 March 19, 2013 11:50
Jump in epsilon values near the wall : low re k-epsilon model malaboss OpenFOAM Verification & Validation 1 February 1, 2013 17:36
How to get reference to k and epsilon in the epsEqn and kEqn cfd_explorer OpenFOAM 0 March 10, 2011 10:58
SimpleFoam k and epsilon bounded nedved OpenFOAM Running, Solving & CFD 1 November 25, 2008 21:21
