June 2, 2014, 16:33 |
Difficulty with mapFields utility
Ron Burnett
Rep Power: 13 |
Following the example in User Guide (p30), I'm able to map data
from one run file (coarse) to another (fine) without an error message: rr@linux-4s0i:~> mapFields -case fine -consistent coarse /*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.2.x | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 2.2.x-71fcc245333b Exec : mapFields -case fine -consistent coarse Date : Jun 02 2014 Time : 13:54:31 Host : "linux-4s0i.site" PID : 2918 Case : ./fine nProcs : 1 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster allowSystemOperations : Disallowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Source: "." "coarse" Target: "." "fine" Create databases as time Source time: 500 Target time: 500 Create meshes Source mesh size: 493014 Target mesh size: 822737 Consistently creating and mapping fields for time 500 interpolating alphat interpolating mut interpolating rho interpolating p interpolating T interpolating k interpolating omega interpolating U End However, ALL the newly created files (alphat, omega, p, etc) have nonsensical entries that were not present in the original file. As an example, from T : 0 0 0 0 (~ line 152,000) 0 0 0 -inf -nan -nan -nan -nan -nan -nan -nan -nan -nan -nan and 1.04273e-308 6.23498e-316 7.59379e-321 (~ line 263,000) 6.23504e-316 6.91256e-310 0 0 2.23595e-310 2.42092e-322 6.23496e-316 6.91256e-310 6.35646e-309 9.34779e-309 4.74303e-322 3.16202e-32 Also, OF version 2.0 (CAElinux disc) behaves in a similar fashion. It appears that this issue has been experienced by others but there is no clear solution. What am I doing wrong? |
[Other] Contribution a new utility: refine wall layer mesh based on yPlus field | lakeat | OpenFOAM Community Contributions | 58 | December 23, 2021 02:36 |
The -parallel parameter of mapFields utility in OpenFOAM v2.3.0 | shuoxue | OpenFOAM Pre-Processing | 1 | April 28, 2014 05:59 |
mapFields utility | openfoammaofnepo | OpenFOAM | 2 | June 29, 2013 16:55 |
mapFields producing "nan" entry | tlandfried | OpenFOAM Pre-Processing | 2 | August 7, 2012 07:40 |
mapFields utility | cristobal | OpenFOAM | 1 | April 1, 2010 11:09 |
