The -parallel parameter of mapFields utility in OpenFOAM v2.3.0
Old   April 15, 2014, 07:44
Default The -parallel parameter of mapFields utility in OpenFOAM v2.3.0
Yao Lu
shuoxue is on a distinguished road
I performed a case which time ranged from 0s to 200s with sparse grid(192000 cells) on 4 processors.
Then, a geometry with better grid(576000 cells) and same BCs was established.
mapFields -consistent <dir>
required so much time, I'd like to execute mapFields with parallel mode.
mapFields -consistent <dir> -parallel
or
mpirun -np 4 mapFields -consistent <dir> -parallel
have been tried and failed.
Is there someone knows how to speed up mapFields with parallel mode?
My OpenFOAM is 2.3.0.
Thanks in advance.
shoxue
shuoxue is offline   Reply With Quote
Old   April 28, 2014, 06:59
Olivier
olivierG is on a distinguished road
hello,
There is a lot of change in the mapFields for 2.3. (and we lost the ability to map from single to parallel case and the opposite).
If you want to keep the old map method (faster), use option "-mapMethod mapNearest".
But for me there is a regression with mapField, so i use the 2.2 version for this tools.
regards,
olivier
olivierG is offline   Reply With Quote
Running Error using Compressible OpenFoam Parallel mode dhendria OpenFOAM Running, Solving & CFD 0 February 13, 2014 21:53
OpenFOAM doesn't run in parallel callumso OpenFOAM Running, Solving & CFD 0 July 11, 2013 13:17
Something weird encountered when running OpenFOAM in parallel on multiple nodes xpqiu OpenFOAM Running, Solving & CFD 2 May 2, 2013 05:59
Purpose of the -parallel parameter GerhardHolzinger OpenFOAM Running, Solving & CFD 2 March 29, 2012 06:56
OpenFOAM 2.0.0. and 2.0.1 doesn't work in parallel mode rv82 OpenFOAM Running, Solving & CFD 3 October 3, 2011 11:47
