heat flux BC in conjugate heat transfere
Old   April 3, 2014, 16:05
Default heat flux BC in conjugate heat transfere
Sergey
skuznet is on a distinguished road
Hello!
I would like to apply fixed heat flux to my solid boundary in a conjugate heat transfer problem. Is there a BC allowing to prescribe heat flux q directly or do I have to use fixedGradient for the temperature grad T=-q/kappa?
Thank you!
skuznet is offline   Reply With Quote
Old   April 3, 2014, 17:42
Alex
zfaraday will become famous soon enough
Hi Sergey,
do you really need another boundary condition than fixedGradient for that? It's the most simple for this purpose, if not the only one...
Regards,
Alex
Web site where I present my Master's Thesis: foamingtime.wordpress.com
The case I talk about in this site was solved with chtMultiRegionSimpleFoam solver and involves radiation. Some basic tutorials are also resolved step by step in the web. If you are interested in these matters, you are invited to come in!
zfaraday is offline   Reply With Quote
Old   April 4, 2014, 10:58
Sergey
It would be just more convenient to prescribe flux directly. If i change, for example, material properties, i would need to change my kappa in BC to keep same flux, which makes more space for mistakes.
Old   May 28, 2014, 19:11
Alex
Maybe it's a bit late or maybe you have already found it, but I think that what you need is externalWallHeatFluxTemperature
Regards,
alex
Old   June 24, 2014, 03:38
Bárbara Arizmendi
Barbara is on a distinguished road
I have used this:
type compressible::turbulentHeatFluxTemperature;
heatSource power;
q uniform 15000;
kappa solidThermo;
kappaName none;
value uniform 700;
but it seems it doesn't work because when I check heat fluxes with wallHeatFlux utility the result is the following:
Time = 8100
Selecting thermodynamics package
type heSolidThermo;
mixture pureMixture;
transport constIso;
thermo hConst;
equationOfState rhoConst;
specie specie;
energy sensibleEnthalpy;
Wall heat fluxes [W]
defaultFaces 0
chapa_to_pedestalinf 0
chapa_to_air 0
chapa_to_pedestalsup 0
I was wondering if anybody has used a succesful wall heat flux boundary condition over a solid or if anybody
Barbara is offline   Reply With Quote
Old   June 24, 2014, 03:39
Bárbara Arizmendi
anybody knows what could be the mistake.
Thanks you in advance,
Bárbara
Old   June 24, 2014, 04:37
Joachim Herb
jherb is on a distinguished road
Have you tried with the correct kappaName? Depending on the OpenFOAM version you use this might be kappaEff or alphaEff.
jherb is offline   Reply With Quote
Old   June 24, 2014, 05:47
Bárbara Arizmendi
I am working with OF 2.2.2
Actually I have tested the same boundary condition adding another line:
heatSource power;
q uniform 15000;
alphaEff alphaEff;
kappa solidThermo;
kappaName none;
value uniform 700;
but the result is the same. Also I've tried the externallWallHeatFlux boundary condition and the results are the same.
Old   June 24, 2014, 07:00
Alex
Barbara, take a look at this thread http://www.cfd-online.com/Forums/sho...d.php?t=136031. Maybe it's something related to it. Sorry for the format, I write from my mobile.
Sign of Heat Flux at wall Kyung FLUENT 2 February 26, 2016 17:25
Calculating heat flux hugo17 OpenFOAM Post-Processing 4 May 27, 2015 13:47
Heat Flux , Convective + Radiant Heat flux Mandeep CFX 3 October 25, 2012 17:57
Heat Flux at wall in a conjugate heat transfer problem Chander CFX 2 July 9, 2011 23:22
Heterogeneous heat flux Kev STAR-CD 4 July 7, 2009 05:48
