OpenFOAM - Boundary conditions
Old   March 21, 2014, 03:58
Default OpenFOAM - Boundary conditions
srirao
sri_fmlab is on a distinguished road
Please help me in setting the appropriate boundary conditions in my simulation.
I am simulating a flow through a tank having one INLET and two OUTLETS. Water is entering the tank at 1m/s velocity and leaving the tank through OUTLET1 which is maintaining at 18000pascals. The pressure inside the tank is 2700pascals and it is maintained by air evacuation through OUTLET2. So pressure at OUTLET is 2700 pascals. The backflow is happening in my simulations because of pressure variation from out let to inlet. please see my attached boundary conditions.
My question is what kind of boundary condition for Alpha, p and u should i specify to develop a water column and make the flow out with out backflow.
Thanks in advance
regards
Sri
sri_fmlab is offline   Reply With Quote
Old   March 28, 2014, 17:01
sajad
seju is on a distinguished road
hi srirao
please change U BC follow this method and give me your results.
FoamFile
version 2.0;
format ascii;
class volVectorField;
location "0";
object U;
dimensions [0 1 -1 0 0 0 0];
internalField uniform (0 0 0);
boundaryField
walls
type fixedValue;
value uniform (0 0 0);
inlet
type fixedValue;
value uniform (0 1 0);
outlet1
type inletOutlet; //fluxCorrectedVelocity;
inletValue uniform (0 0 0);
outlet2
type pressureInletOutletVelocity;
simmetry
type fixedValue;
wall1
type fixedValue;
wall2
type fixedValue;
seju is offline   Reply With Quote
How the boundary conditions are called in the OpenFOAM solvers? openfoammaofnepo OpenFOAM Programming & Development 15 February 11, 2020 05:28
non reflective boundary conditions for incompresible flow Pascal_doran OpenFOAM Programming & Development 16 August 25, 2015 06:35
inlet boundary conditions newOFuser OpenFOAM 1 January 10, 2013 09:08
Boundary conditions for 2D Navie-Stockes simulation L1011 OpenFOAM 5 December 13, 2012 09:17
[Commercial meshers] exporting boundary conditions with pointwise -> openFoam ebah6 OpenFOAM Meshing & Mesh Conversion 2 September 16, 2012 17:57
