March 17, 2014, 17:36 |
OpenFoam 2.3.0 vs 2.2.2 Parallel Running
Tom Ankrom
Rep Power: 13 |
I've managed to get OpenFoam 2.3.0 installed to Fedora 20 following the link to OpenFoam Wiki, Most things are working except running the cases in parallel. The meshing process seems to work fine, but following the run of decomposePar nothing gets split between the processors (the folders appear correctly - ie processor*) and the case completes immediately with no results. The same cases work fine under 2.2.2 (from the RPM pack)? Could anybody tell me what Im doing wrong? Thanks |
March 21, 2014, 18:39 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Greetings Tom and welcome to the forum!
Well... without knowing what were the exact steps you've taken and with which case and/or tutorial case, it's really complicated to guess what you might be doing wrong and/or right. Therefore, my best guess is that the wrong step you've done is to not have read this thread: http://www.cfd-online.com/Forums/ope...-get-help.html Best regards, Bruno
Large test case for running OpenFoam in parallel | fhy | OpenFOAM Running, Solving & CFD | 23 | April 6, 2019 10:55 |
simpleFoam parallel | AndrewMortimer | OpenFOAM Running, Solving & CFD | 12 | August 7, 2015 19:45 |
parallel error with cyclic BCs for pimpleDyMFoam and trouble in resuming running | sunliming | OpenFOAM Bugs | 21 | November 22, 2013 04:38 |
Running in parallel | Djub | OpenFOAM Running, Solving & CFD | 3 | January 24, 2013 17:01 |
OpenFOAM 14 stock version parallel bug | msrinath80 | OpenFOAM Bugs | 2 | May 30, 2007 15:47 |
