Partial field mapping
Old   February 28, 2014, 14:04
Post Partial field mapping
Vincent Leroy
leroyv is on a distinguished road
Dear foamers,
I ran a simulation on a geometry visible here:
https://www.dropbox.com/s/72wla3nfb5udb0y/all_cells.png
I'd like to map the solution fields on the upper right cell onto this geometry:
https://www.dropbox.com/s/sbqzbofwtp3kq2p/unit_cell.png
Both meshes are identically built, so it's basically just about cropping and translating the results. I know that the mapFields utility is meant to do things like this, but I don't know if it is appropriate my case. Maybe offsetting the unit cell mesh coordinates would be the thing to do?
Do you have any advice for the use of mapFields?
Vincent
leroyv is offline   Reply With Quote
Old   May 24, 2016, 22:45
Karelke Yu
cfdopenfoam is on a distinguished road
hi, Vincent. may i know how you finally solved your problem?
cfdopenfoam is offline   Reply With Quote
Old   May 25, 2016, 07:00
Vincent Leroy
Hi Karelke,
That was more than 2 years ago so my memory might be a bit fuzzy. From what I remember, I did what I suggested: I offset the target mesh to center it at the position corresponding to the cell I wanted to map in the source mesh, using the transformPoints utility. Then I used mapFields with the cellPointInterpolate method to map the field to the target mesh. As far as I know, mapFields has been quite deeply modified since then, so you will need to look into it to see if better interpolation methods are available.
I hope that helps! Best regards,
Vincent
Old   May 25, 2016, 07:43
Karelke Yu
Originally Posted by leroyv View Post
Hi Karelke,
Vincent
thank you for your hints, Vincent. I will have a try!
field mapping, mapfields, openfoam
problems after decomposing for running alessio.nz OpenFOAM 7 March 5, 2021 05:49
Mapping field to a subdomain Lense OpenFOAM Pre-Processing 2 May 24, 2016 22:43
Cht tutorial in 15 braennstroem OpenFOAM Running, Solving & CFD 197 June 10, 2015 04:02
How to get the velocity field from the pressure field Hermano Main CFD Forum 2 November 29, 2011 09:32
mapping of pressure field (simplefoam to cavitatingFoam) siddharameshwara OpenFOAM Running, Solving & CFD 14 February 15, 2011 09:59
