February 12, 2014, 14:23 |
Liquid plug using interFoam
Praveen Srikanth
Rep Power: 14 |
Hey all,
I am trying to simulate transitions between a liquid plug and a droplet using interFoam. My geometry is just a cylindrical capillary with a liquid plug set by the setFields utility. There are two ways to observe the transition. One is by varying the contact angle which I believe can be done by using the timeVaryingAlphaContactAngle but I am yet to figure out how to do it. The other way is by removing fluid from the plug forcing it to become a droplet which is much more physical than changing the contact angle. But I am not able to figure out how to remove fluid from the liquid plug region. Any help would be appreciated. I am pretty new to OF to I don't really know much Many thanks |
February 16, 2014, 02:00 |
Help Appreciated
Praveen Srikanth
Rep Power: 14 |
Hey,
I am still stuck at the same point and I am unable to figure out how to remove the liquid. I have attached an image with the capillary and the liquid plug and I want to remove fluid from the liquid plug region to view its collapse. |
interface, interfoam, liquid plug |
static pressure BC for interFoam | kwardle | OpenFOAM | 2 | March 4, 2015 04:29 |
InterFoam negative alpha | karasa03 | OpenFOAM | 7 | December 12, 2013 03:41 |
Thin liquid FILM breaks with InterFOAM | ovie | OpenFOAM | 5 | June 25, 2010 13:18 |
DNS of liquid sheets using interfoam and blockMesh | kumar | OpenFOAM | 8 | June 3, 2010 11:57 |
How to calculate liquid volume as the interface moves for interFoam Solver | asaha | OpenFOAM Running, Solving & CFD | 25 | October 21, 2009 04:34 |
