thermophysicalProperties in simpleFOAM
Old   December 17, 2013, 03:57
Default thermophysicalProperties in simpleFOAM
Marcus
marcus85 is on a distinguished road
Hello to all,
i want to set up an incompressible steady state study of an cooling water jacket.
No my Problem is how i should define the thermophysicalProperties, because almost all of the tutorials didn't include any thermophysicalProperties file and now i'm confused about this fact:
Do i need this file for my case?
If i don't need it: Where i've to define the constants of this file?
If i need: Which thermoType should i use?
(The file i attached is only from my setup for my rhoSimpleFoam cases:
| \\ / O peration | Version: 2.0.1 |
| \\ / A nd | Web: www.OpenFOAM.com |
| \\/ M anipulation | |
FoamFile
version 2.0;
format ascii;
class dictionary;
location "constant";
object thermophysicalProperties;
thermoType hPsiThermo<pureMixture<constTransport<specieThermo <hConstThermo<perfectGas>>>>>;
mixture
specie
nMoles 1;
molWeight 28.9;
thermodynamics
Cp 1000;
Hf 0;
transport
mu 1.8e-05;
Pr 0.7;
and another question for the setup is:
Should i define another model in the transportProperties file in my constant directory? Because i've seen, that there are other definitions in the tutorial Cases and there is the opportunity of two models i can use. Did somebody make experiences with this special models an how they work for validation?
Here is my file:
object transportProperties;
transportModel Newtonian;
nu nu [ 0 2 -1 0 0 0 0 ] 4.74e-07;
Prt Prt [ 0 0 0 0 0 0 0 ] 0.9;
Pr Pr [ 0 0 0 0 0 0 0 ] 3;
rho rho [ 1 -3 0 0 0 0 0 ] 983.19;
k k [ 1 1 -3 -1 0 0 0 ] 0.647;
Cp Cp [ 0 2 -2 -1 0 0 0 ] 4182;
Thanks for all supply...
best regards
Marcus
marcus85 is offline   Reply With Quote
incompressible flow, steady-state, thermophysicalproperties, transportproperties
interFoam vs. simpleFoam channel flow comparison DanM OpenFOAM Running, Solving & CFD 12 January 31, 2020 16:26
simpleFoam parallel AndrewMortimer OpenFOAM Running, Solving & CFD 12 August 7, 2015 19:45
Laminar simpleFoam and inviscid simpleFoam herenger OpenFOAM Running, Solving & CFD 7 July 11, 2013 07:27
Trying to run a benchmark case with simpleFoam spsb OpenFOAM 3 February 24, 2012 10:07
Naca0012 k-e mpirun gives fpe whereas simpleFoam not Pierpaolo OpenFOAM 1 May 8, 2010 04:08
