BC for measuring force on blunt body
Old   December 8, 2013, 19:36
Default BC for measuring force on blunt body
letthe is on a distinguished road
I'm trying to measure force exerted on a blunt body by a constant flow using "forces" function but the forces are always with a very low value (0.0005).
0/U:
body
type fixedValue;
value uniform (0 0 0);
0/p:
body
type zeroGradient;
This is a 3D case.
letthe is offline   Reply With Quote
Old   December 9, 2013, 16:27
W. Schuyler Hinman
schuyler is on a distinguished road
Did you make sure you have everything defined correctly in the forceCoeffs dictionary?
S.
schuyler is offline   Reply With Quote
Old   December 9, 2013, 18:43
S.
You mean in the forces dictionary, right?
forces
type forces;
functionObjectLibs ("libforces.so");
outputControl timeStep;
outputInterval 5;
patches ( "blunt_object" );
pName p;
UName U;
rhoName rhoInf;
log true;
CofR (0 0 0);
rhoInf 1000;
Old   December 9, 2013, 19:15
W. Schuyler Hinman
forces
type forces;
outputInterval 5;
pName p;
UName U;
rhoName rhoInf;
log true;
CofR (0 0 0);
rhoInf 1000;
Looks right to me... Your BCs look right too. If your geometry isnt complicated you can check the force calculation yourself manually with the output pressure (and shear if its significant). It could just be something such as a unit conversion problem for your geometry. Like if you have a multiplier in blockmesh and didn't realize it etc. Double check the size of your blunt object. If it is a small object in the simulation it will have small force.
Other than that I'm out of ideas sorry! Maybe someone else will be more helpful.
Old   December 9, 2013, 19:20
You have been very helpful, thank you! I am now convinced that this is a problem of units ... fingers crossed I find it
ActuatorDiskExplicitForce in OF2.1. Help be_inspired OpenFOAM Programming & Development 10 September 14, 2018 12:12
force convergence problems in CFX 6DOF rigid body solver ajay_ks CFX 8 March 25, 2013 05:02
Force can not converge colopolo CFX 13 October 4, 2011 23:03
Body force at the cell face Souviktor Fluent UDF and Scheme Programming 0 March 31, 2009 09:54
UDF for lift force on a bluff body sawa FLUENT 2 April 11, 2005 04:06
