L M
Rep Power: 0 ![]() |
Hi all,
I'm a beginners so please forgive me if my questions are dumb... I'm trying to use fireFoam (v2.2) for multiple reaction combustion. In particular, I'm trying to simulate a diffusion flame with spray injection. I'm using: thermoType { type hePsiThermo; mixture reactingMixture; transport sutherland; thermo janaf; energy sensibleEnthalpy; equationOfState perfectGas; specie specie; } The code runs, but no combustion is started. I'm sure the reactions are correct (they work when using reactingFoam), so I guess the problem is in setting the constant files for combustion. It only works correctly when using only one reaction. I would like to know if anybody else has tried something similar: do you know how to set the case for multiple reaction? Do you know if there are any documents/tutorials I can study to understand deeper how fireFoam works? I've seen dieselFoam was quite similar to what I'm trying to study: do you know if there's something similar in v2.2? Thank you all!!! |
Sameer
Rep Power: 14 ![]() |
Can we model multiple reactions in reactingFoam ?
#3 | |
Sameer
firefoam |
how to set periodic boundary conditions | Ganesh | FLUENT | 15 | November 18, 2020 06:09 |
[snappyHexMesh] determining displacement for added points | CFDnewbie147 | OpenFOAM Meshing & Mesh Conversion | 1 | October 22, 2013 09:53 |
Segmentation fault in running alternateSteadyReactingFoam,why? | NewKid | OpenFOAM | 18 | January 20, 2011 16:55 |
Warning 097- | AB | Siemens | 6 | November 15, 2004 04:41 |
chemical reaction - decompostition | La S. Hyuck | CFX | 1 | May 23, 2001 00:07 |
