decomposerPar Warning
Old   October 28, 2013, 18:49
Default decomposerPar Warning
Krishna
rkc.cfd is on a distinguished road
I have successfully compiled OpenFOAM ext1.6. I get the following error when I run decomposePar. The simulation runs fine, it is converging and all is fine. I am just curious if the warning should be addressed?
FOAM Warning :
From function IOstream::compressionEnum(const word&)
in file db/IOstreams/IOstreams/IOstream.C at line 75
bad compression specifier 'off', using 'uncompressed'
rkc.cfd is offline   Reply With Quote
Old   October 29, 2013, 18:51
Retired Super Moderator
Bruno Santos
Quick question: what does the file "system/controlDict" contain?
Old   October 30, 2013, 18:43
Krishna
Thanks, I had the writeCompression option as:
writeCompression off
instead it should be
writeCompression uncompressed
Cheers
decomposepar, foam warning, uncompressed
[swak4Foam] installation problem with version 0.2.3 Claudio87 OpenFOAM Community Contributions 9 May 8, 2013 11:20
[blockMesh] BlockMesh FOAM warning gaottino OpenFOAM Meshing & Mesh Conversion 7 July 19, 2010 15:11
latest OpenFOAM-1.6.x from git failed to compile phsieh2005 OpenFOAM Bugs 25 February 9, 2010 05:37
Compilation errors in ThirdPartymallochoard feng_w OpenFOAM Installation 1 January 25, 2009 07:59
[blockMesh] Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Meshing & Mesh Conversion 10 April 2, 2007 15:00
