October 21, 2013, 07:11
Nima Samkhaniani
which solver do you use?
if you are using *porous*solver in OpenFOAM, then you need just define your zone in topoSet, then appropriate source term will be applied in conservative Eq.s and no specific BC needed.
To find out how to create a zone look at following tutorials:
./lagrangian/reactingParcelFilmFoam/splashPanel/system/wallFilmRegion.topoSet
./lagrangian/reactingParcelFilmFoam/splashPanel/system/wallFilmRegion/createWallFilmRegionPatches.topoSet
./lagrangian/reactingParcelFilmFoam/hotBoxes/system/topoSetDict
./lagrangian/reactingParcelFilmFoam/cylinder/system/topoSetDict
./lagrangian/reactingParcelFilmFoam/rivuletPanel/system/wallFilmRegion.topoSet
./lagrangian/coalChemistryFoam/simplifiedSiwek/system/topoSetDict
./lagrangian/reactingParcelFoam/filter/system/topoSetDict
./mesh/moveDynamicMesh/simpleHarmonicMotion/system/topoSetDict
./multiphase/MRFMultiphaseInterFoam/mixerVessel2D/system/topoSetDict
./multiphase/twoPhaseEulerFoam/mixerVessel2D/system/topoSetDict
./multiphase/interDyMFoam/ras/damBreakWithObstacle/system/topoSetDict
./multiphase/interDyMFoam/ras/floatingObject/system/topoSetDict
./multiphase/MRFInterFoam/mixerVessel2D/system/topoSetDict
./multiphase/interFoam/ras/damBreakPorousBaffle/system/topoSetDict
./multiphase/interFoam/les/nozzleFlow2D/system/topoSetDict.2
./multiphase/interFoam/les/nozzleFlow2D/system/topoSetDict.1
./multiphase/compressibleTwoPhaseEulerFoam/mixerVessel2D/system/topoSetDict
./multiphase/cavitatingFoam/ras/throttle/system/topoSetDict.3
./multiphase/cavitatingFoam/ras/throttle/system/topoSetDict.2
./multiphase/cavitatingFoam/ras/throttle/system/topoSetDict.1
./multiphase/cavitatingFoam/les/throttle3D/system/topoSetDict.3
./multiphase/cavitatingFoam/les/throttle3D/system/topoSetDict.2
./multiphase/cavitatingFoam/les/throttle3D/system/topoSetDict.1
./multiphase/cavitatingFoam/les/throttle/system/topoSetDict.3
./multiphase/cavitatingFoam/les/throttle/system/topoSetDict.2
./multiphase/cavitatingFoam/les/throttle/system/topoSetDict.1
./multiphase/multiphaseEulerFoam/mixerVessel2D/system/topoSetDict
./combustion/PDRFoam/flamePropagationWithObstacles/system/topoSetDict
./combustion/fireFoam/les/smallPoolFire3D/system/topoSetDict
./combustion/fireFoam/les/oppositeBurningPanels/f.topoSetDict
./combustion/fireFoam/les/oppositeBurningPanels/fBurner.topoSetDict
./combustion/fireFoam/les/oppositeBurningPanels/cRefine.topoSetDict
./combustion/fireFoam/les/smallPoolFire2D/system/topoSetDict
./incompressible/pimpleDyMFoam/mixerVesselAMI2D/system/topoSetDict
./incompressible/pimpleDyMFoam/propeller/system/createInletOutletSets.topoSetDict
./incompressible/pimpleDyMFoam/propeller/system/removeRedundantZones.topoSetDict
./incompressible/pimpleDyMFoam/propeller/system/createAMIFaces.topoSetDict
./incompressible/simpleFoam/turbineSiting/system/topoSetDict
./incompressible/simpleFoam/pipeCyclic/system/topoSetDict
./incompressible/pimpleFoam/TJunctionFan/system/topoSetDict
./incompressible/pimpleFoam/elipsekkLOmega/system/topoSetDict
./incompressible/potentialFreeSurfaceFoam/oscillatingBox/system/topoSetDict
./heatTransfer/chtMultiRegionSimpleFoam/heatExchanger/system/air/topoSetDict.2
./heatTransfer/chtMultiRegionSimpleFoam/heatExchanger/system/air/topoSetDict.1
./heatTransfer/chtMultiRegionSimpleFoam/multiRegionHeater/system/topoSetDict
./heatTransfer/chtMultiRegionSimpleFoam/multiRegionHeaterRadiation/system/topoSetDict
./heatTransfer/buoyantSimpleFoam/circuitBoardCooling/system/topoSetDict
./heatTransfer/chtMultiRegionFoam/multiRegionHeater/system/topoSetDict
./heatTransfer/chtMultiRegionFoam/multiRegionLiquidHeater/system/topoSetDict
