Error in thermophysical properties (chtMultiRegionFoam) |
November 17, 2015, 13:56 |
#21 |
S Atkinson
Rep Power: 11 |
Hi Wyldckat,
I am having the same issues as fkika. I have a smaller model with convection and heat transfer working correctly with the same thermophysical properties. I was using 2.4 but I just upgraded to 3.0 using the standard instructions on the Openfoam website. Both versions received the same error. FOAM FATAL ERROR: Kappa defined to employ fluidThermo method, but thermo package not available From function temperatureCoupledBase::kappa(const scalarField&) const in file turbulentFluidThermoModels/derivedFvPatchFields/temperatureCoupledBase/temperatureCoupledBase.C at line 138. I tried understanding the source code, however it is fairly difficult to understand what each variable is. Thanks! |
November 18, 2015, 15:34 |
#22 | ||
Alex
Rep Power: 22 |
Hi Atkinson!
You provided more information than the previous fellow, however, you only provided the answer to one out of four questions Bruno did... Quote:
Well, first of all, I never saw this message before. I don't know if it is a new, or modified, message included from version 2.4 on (the last version I worked with is 2.3.x), or if I am too good! Having said that, according to what the error message says, I would point out the following possible information you likely missed:
Maybe if you check this information you can figure out what is going wrong. Hope it helps. Best regards, Alex
Web site where I present my Master's Thesis: foamingtime.wordpress.com The case I talk about in this site was solved with chtMultiRegionSimpleFoam solver and involves radiation. Some basic tutorials are also resolved step by step in the web. If you are interested in these matters, you are invited to come in! |
November 18, 2015, 17:58 |
#23 |
S Atkinson
Rep Power: 11 |
Hi Alex,
Thanks for your quick reply. I have attached a txt file onto the forum with my thermophysicalpropperties but it doesn't seem to show up on windows systems. Here is the code; Code:
thermoType { type heRhoThermo; mixture pureMixture; transport const; thermo hConst; equationOfState perfectGas; specie specie; energy sensibleEnthalpy; } mixture { specie { nMoles 1; molWeight 4; } thermodynamics { Cp 5195; Hf 0; } transport { mu 2.71191e-4; Pr 0.66; } } I am using helium as a compressible flow, in the new version of openfoam it insisted I used a mut file instead of a nut file (which seemed a bit odd). I have not tried to get this error on any tutorials, how would I go about doing that? I installed the new Openfoam version 3.0 using the instructions on the website. The instructions are found here; http://www.openfoam.org/download/ubuntu.php I did not receive any errors on my system. Thanks! |
November 22, 2015, 17:28 |
#24 | |||
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Greetings to all!
Curiously enough, I helped update the code documentation for this boundary condition a few days before 3.0.0 was released: http://www.openfoam.org/mantisbt/view.php?id=1875 And Alex has the right idea: Quote:
Another example is this: http://openfoamwiki.net/index.php/Ge..._-_planeWall2D - which is essentially a tutorial that forces the person reading it to play with the case and test what each bit does... @satkinson: And if you still have problems with figuring out the problem, please follow the instructions given here: http://www.cfd-online.com/Forums/ope...-get-help.html Best regards, Bruno
November 23, 2015, 09:17 |
#25 |
S Atkinson
Rep Power: 11 |
Hi All,
I checked the Temperature files as mentioned and one of them was incorrectly labled as fluidthermo. Thanks so much! |
April 12, 2016, 04:12 |
#26 | |
Dear Bruno one question about turbulentHeatFluxTemperature BCs. Since you once helped in updating the documentation (http://www.openfoam.org/mantisbt/view.php?id=1875) maybe you have some idea.
In OpenFOAM 2.4 it was possible to use an incompressible solver like buoyantBoussinesqSimpleFoam and set in the T file a patch with type turbulentHeatFluxTemperature In OF 3.0 on the contrary I get the error Quote:
I have noticed that in OF24 turbulentHeatFluxTemperature can be found in incompressible: https://github.com/OpenFOAM/OpenFOAM...hScalarField.H while in OF301 can be found only in compressible: src/TurbulenceModels/compressible/turbulentFluidThermoModels/derivedFvPatchFields/turbulentHeatFluxTemperature/turbulentHeatFluxTemperatureFvPatchScalarField.H Do you know the reason? |
April 13, 2016, 04:12 |
#27 |
I used the following workaround to solve the issue:
1) switch solver: use buoyantSimpleFoam instead of buoyantBoussinesqSimpleFoam 2) copy from the tutorial /heatTransfer/buoyantSimpleFoam/hotRadiationRoom/constant the thermophysicalProperties file; and set the equationOfState to Boussinesq; Code:
thermoType { type heRhoThermo; mixture pureMixture; transport const; thermo hConst; equationOfState Boussinesq; //hConst; specie specie; energy sensibleEnthalpy; } pRef 100000; mixture { specie { nMoles 1; molWeight 28.9; } thermodynamics { Cp 1000; Hf 0; } transport { mu 1.8e-05; Pr 0.7; } equationOfState { rho0 1.225; T0 273; beta 2; } } Code:
floor { type compressible::turbulentHeatFluxTemperature; gradient uniform 0; heatSource power; q uniform 64; kappa fluidThermo; kappaName none; } Code:
SIMPLE: convergence criteria field p_rgh tolerance 0.01 field U tolerance 0.001 field h tolerance 0.001 field G tolerance 0.001 field "(k|epsilon|omega)" tolerance 0.001 Reading thermophysical properties Selecting thermodynamics package { type heRhoThermo; mixture pureMixture; transport const; thermo hConst; equationOfState Boussinesq; specie specie; energy sensibleEnthalpy; } Reading field U Reading/calculating face flux field phi Creating turbulence model Selecting turbulence model type RAS Selecting RAS turbulence model kEpsilon kEpsilonCoeffs { Cmu 0.09; C1 1.44; C2 1.92; C3 -0.33; sigmak 1; sigmaEps 1.3; } Reading g Reading hRef Calculating field g.h Reading field p_rgh No MRF models present No finite volume options present Selecting radiationModel P1 Selecting absorptionEmissionModel constantAbsorptionEmission Selecting scatterModel none Selecting sootModel none Selecting transmissivityModel none Starting time loop Time = 1 DILUPBiCG: Solving for Ux, Initial residual = 1, Final residual = 0.00446568, No Iterations 1 DILUPBiCG: Solving for Uy, Initial residual = 1, Final residual = 0.00440658, No Iterations 1 DILUPBiCG: Solving for Uz, Initial residual = 1, Final residual = 0.0020939, No Iterations 1 DILUPBiCG: Solving for h, Initial residual = 1, Final residual = 0.000306369, No Iterations 1 DICPCG: Solving for G, Initial residual = 1, Final residual = 0.0877135, No Iterations 16 DICPCG: Solving for p_rgh, Initial residual = 0.802888, Final residual = 0.00664506, No Iterations 25 time step continuity errors : sum local = 0.028538, global = 1.78087e-17, cumulative = 1.78087e-17 rho max/min : -64.9248 -554.925 DILUPBiCG: Solving for epsilon, Initial residual = 0.0201837, Final residual = 0.0002457, No Iterations 1 bounding epsilon, min: -0.0462023 max: 0.253471 average: 0.0444903 DILUPBiCG: Solving for k, Initial residual = 1, Final residual = 0.0120747, No Iterations 1 ExecutionTime = 1.05 s ClockTime = 1 s Time = 2 http://www.openfoam.org/mantisbt/view.php?id=1856 https://develop.openfoam.com/Develop...plus/issues/96 |
October 5, 2017, 07:48 |
#28 | ||
vaibhav
Rep Power: 10 |
This error is caused by rhoThermo model for fluid region, so please check your initial value settings in 0/p, T, k, epsilon, p_rgh file. If the initial value is equal 0 in fluid region or solid-fluid interface, floating point exception will be caused. |
November 23, 2021, 07:34 |
ERROR: Cannot find a fluidThermo or solidThermo instance
#29 |
Dear Foamers,
I am very new to openfoam and CFD, kindly I need your help. I have been simulating conjugate heat transfer between solid(wall) to fluid. So i used externalWallHeatFluxHeatTransfer boundary condition on the wall surfaces and used kappaMethod as solidThermo on my temperature(T) file. After i started to run my solver, I encounter this error , --> FOAM FATAL ERROR: Cannot find a fluidThermo or solidThermo instance From function Foam::tmp<Foam::Field<double> > Foam::temperatureCoupledBase::kappa(const fvPatchScalarField&) const in file derivedFvPatchFields/temperatureCoupledBase/temperatureCoupledBase.C at line 124. FOAM exiting. How to solve this error? Thanks Rishi |
chtmultiregionfoam, error, plasma actuator modeling, pre-processing |
table properties for thermophysical properties | romant | OpenFOAM Running, Solving & CFD | 1 | August 12, 2014 09:41 |
thermophysical properties | immortality | OpenFOAM Running, Solving & CFD | 0 | December 2, 2012 07:49 |
polynomial thermophysical properties in a solid region (chtMultiRegionSimpleFoam) | Koga | OpenFOAM Programming & Development | 0 | November 15, 2012 05:14 |
how to incorporate temperature dependent thermophysical properties in fluent. | CANDY | Fluent UDF and Scheme Programming | 4 | October 22, 2012 05:19 |
thermophysical properties of ham | Alex Ivancic | Main CFD Forum | 1 | November 5, 1998 12:09 |
