'Cannot find patchField entry for outlet'
Like Tree22Likes
Old   July 12, 2023, 04:32
Default Unable to run interFoam (for channel flow)
  #21
Tanmoy Majumder
tanmoy@1995 is on a distinguished road
I have started learning OpenFOAM recently, for my thesis work, and I'm also new to CFD. Basically, I'm trying to analyze the flow dynamics of an open channel in the presence of obstructions (such as wooden debris and vegetation). But I'm stuck with an error "Cannot find patchField entry for Inlet".
I have been trying to solve this error, but I'm unable to do so. I came across this thread while searching for a solution.
I am posting the error which I got after running interFoam.
--> FOAM FATAL IO ERROR:
file: C:/blueCFD/ofuser-of5/RUN/WATERCHANNEL_1/0/U.boundaryField from line 25 to line 19.
From function void Foam::GeometricField<Type, PatchField, GeoMesh>::Boundary::readField(const Foam:imensionedField<TypeR, GeoMesh>&, const Foam::dictionary&) [with Type = Foam::Vector<double>; PatchField = Foam::fvPatchField; GeoMesh = Foam::volMesh]
in file X:/OpenFOAM-5.x/src/OpenFOAM/fields/GeometricFields/GeometricField/GeometricBoundaryField.C at line 191.
The WATERCHANNEL_1/0/U. file code is provided below.
\\ / F ield | OpenFOAM: The Open Source CFD Toolbox
\\ / O peration | Website: https://openfoam.org
\\ / A nd | Version: 8
\\/ M anipulation |
FoamFile
version 2.0;
format ascii;
class volVectorField;
object U;
dimensions [0 1 -1 0 0 0 0];
internalField uniform (1 0 0);
boundaryField
inlet
type flowRateInletVelocity;
volumetricFlowRate constant 50;
walls
type noSlip;
atmosphere
type pressureInletOutletVelocity;
value uniform (0 0 0);
outlet
type inletOutlet;
inletValue uniform (0 0 0);
value $internalField;
Please suggest any solution.
Thank you, Tanmoy
tanmoy@1995 is offline   Reply With Quote
patch, patch type, patchfield
OpenFoam171: error /usr/bin/ld: cannot find -llduSolvers Schipper OpenFOAM Programming & Development 9 August 26, 2020 06:31
OpenFOAM 1.6-ext git installation on Ubuntu 11.10 x64 Attesz OpenFOAM Installation 45 January 13, 2012 13:38
Problem Building OF on Centos cluster (no admin rights) CKH OpenFOAM Installation 5 November 13, 2011 07:32
Converting Starccm+ mesh Ladnam OpenFOAM 0 September 14, 2011 07:30
Entry level CFD Jobs Section Tez Main CFD Forum 1 February 20, 2007 02:19
