October 2, 2013, 08:38 |
Inlet and Outlet as one sphere???
Rep Power: 13 |
Hello together,
I have some questions on OpenFoam. I've converted a TAU- Mesh into the OF format via Fluent and with TAU we use two spheres to define the near- and farfield around the geometry. We are defining the machnumber and the temperature and pressure and the incoming velocity vectors are all parallel to the flight direction. My question is: is it possible to define a sphere(farfield) for inlet and outlet in openfoam or have there to be always two faces, one for inlet and one for outlet, like building a mesh via blockmesh? I hope u know what I mean and you can help me. Best regards, CFDNEWBIE147 |
October 3, 2013, 04:52 |
Henrik Rusche
Rep Power: 18 |
Dear CFDNEWBIE147,
rather than splitting the patch, I suggest that you use a boundary condition which switched automatically from fixedValue to zeroGradient based on the flux. 0/U: inlet { type inletOutlet; inletValue uniform (1 1 0); value uniform (1 1 0); } 0/p: pressure-far-field-1 { type zeroGradient; } Don't forget to apply inletOutlet on other variables (k, epsilon) in the same manner. Best Regards, Henrik |
October 9, 2013, 03:39 |
Rep Power: 13 |
Dear henrik,
thank you for your reply. If I change the 0/U to what you've said, there's an error that OF wants a scalar and not a vector... What's wrong about this? And can you please explain, how to apply inletOutlet on the other variables? I don't really know how to do this... I hope you can help me again. Best regards, CFDnewbie147 |
October 9, 2013, 04:49 |
Henrik Rusche
Rep Power: 18 |
Hard to say without further information. The error is probably what OpenFOAM says: It needs a vector "(1 0 0)", but it found a scalar "1". Please post the full error message line and the part of the input that OF is referring to in that message.
October 9, 2013, 07:43 |
#5 | |
Dr. B T KANNAN
Rep Power: 15 |
inletValue uniform (0 0 0); instead of inletValue uniform 0: -- KANNAN |
October 9, 2013, 08:36 |
Andreas Groß
Rep Power: 13 |
In addition to Henriks comment, I would suggest to use outletInlet for the pressure on the farfield where you use inletOutlet for the velocity.
Based on the flux, those two bc switch between Neumann and Dirichlet type. inletOutlet is fixed value for inflow and zero gradient for outflow (what Henrik suggested for velocity and the other parameters) outletInlet is the other way round, so it is zero gradient when flux is pointing into the domain and fixed value when the flow is going out of the domain. so, for 0/p in an incompressible flow: inlet { type outletInlet; outletValue uniform 0; // the fixed value, when it is an outlet value uniform 0; // current value (initial guess), will be updated where the flow is into domain } |
October 9, 2013, 10:11 |
Rep Power: 13 |
Hello again,
Here is my polyMesh/boundary file: Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.2.1 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class polyBoundaryMesh; location "constant/polyMesh"; object boundary; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // 8 ( B_11 { type wall; inGroups 1(GeoWallGroup); nFaces 540; startFace 17381367; } B_10 { type wall; inGroups 1(GeoWallGroup); nFaces 7602; startFace 17381907; } B_13 { type wall; inGroups 1(GeoWallGroup); nFaces 4284; startFace 17389509; } B_12 { type wall; inGroups 1(GeoWallGroup); nFaces 24550; startFace 17393793; } B_2//Farfield { type patch; nFaces 1442; startFace 17418343; } B_4 { type wall; inGroups 1(GeoWallGroup); nFaces 26742; startFace 17419785; } B_6 { type wall; inGroups 1(GeoWallGroup); nFaces 7286; startFace 17446527; } B_8 { type wall; inGroups 1(GeoWallGroup); nFaces 2450; startFace 17453813; } ) // ************************************************************************* // And this is my 0/U file, which i adopted to what you've said: Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.2.1 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class volVectorField; object U; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 1 -1 0 0 0 0]; internalField uniform (50 0 0); boundaryField { B_2 { type inletOutlet; inletValue uniform (1 1 0); value uniform (1 1 0); } } GeoWallGroup { type fixedValue; value uniform (0 0 0); } } // ************************************************************************* // I hope you can help me, CFDnewbie147 |
October 9, 2013, 10:49 |
Andreas Groß
Rep Power: 13 |
There is one and maybe a second error:
There is one red curly bracket, which shouldn't be there, as boundaryField {...} should be closed after GeoWallGroup{...}. The maybe-error is the difference in the values for internalField and inletValue. I guess, the flow velocity is 50 m/s in x-wise direction, so you should set both, value and inletValue to (50 0 0). But thats only a guess ;-) Code:
internalField uniform (50 0 0); boundaryField { B_2 { type inletOutlet; inletValue uniform (1 1 0); value uniform (1 1 0); } } GeoWallGroup { type fixedValue; value uniform (0 0 0); } } As Henrik and me wrote above, use inletOutlet for U and other fields like turbulence parameters, temperature, density, etc. on the farfield. For the pressure I would use outletInlet for the pressure Code:
October 9, 2013, 20:11 |
#9 |
Henrik Rusche
Rep Power: 18 |
I agree:
- the 'red' bracket is definitely wrong - the different values will slow down convergence, but the BC will win. - Other variables are k, epsilon, omega, ... treat like velocity (so inletOutlet), but with a sensible scalar value - outletInlet on p - yes, another option - Should not be very different Additional comments: You may want to use $internalField in the BC. See $FOAM_TUT/compressible/rhoPimpleFoam/angledDuct/0/T None of this explains the error message which you are reporting. If it prevails, please post the complete message together with the relevant sections of the file it refers to. Ah, and pressure should be 100000 in case you are running a variable density solver. |
October 15, 2013, 02:41 |
#10 |
Rep Power: 13 |
Hello again,
thank you for your answers. I will try what you've said and post what's going on with the simulation. Best regards, CFDNewbie147 |
October 15, 2013, 10:58 |
#11 |
Rep Power: 13 |
Back again.
It worked, but not as I would it should work. Here are my 0/ files: Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.2.1 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class volVectorField; object U; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 1 -1 0 0 0 0]; internalField uniform (50 0 0); boundaryField { B_2 { type inletOutlet; inletValue uniform (50 0 0); value uniform (50 0 0); } GeoWallGroup { type fixedValue; value uniform (0 0 0); } } // ************************************************************************* // Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.2.1 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class volScalarField; object p; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 2 -2 0 0 0 0]; internalField uniform 100000; boundaryField { B_2 { type outletInlet; outletValue uniform 100000; value uniform 100000; } GeoWallGroup { type zeroGradient; } } // ************************************************************************* // Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.2.1 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class volScalarField; object nuTilda; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 2 -1 0 0 0 0]; internalField uniform 0.14; boundaryField { B_2 { type inletOutlet; inletValue uniform 0.14; value uniform 0.14; } GeoWallGroup { type fixedValue; value uniform 0; } } // ************************************************************************* // Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.2.1 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class volScalarField; object nut; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 2 -1 0 0 0 0]; internalField uniform 0.14; boundaryField { B_2 { type inletOutlet; inletValue uniform 0.14; value uniform 0.14; } GeoWallGroup { type nutUSpaldingWallFunction; value uniform 0; } } // ************************************************************************* // I think I have to fix the direction of the velocity with a main vector with 50m/s only in x- direction? How can I do this? Hope you can help again, best regards, CFDNewbie147 |
define BCs at inlet and outlet for natural ventilation simulation | jjz2013 | Main CFD Forum | 0 | January 29, 2013 16:50 |
Pulsatile pressure inlet with pressure outlet | a.lynchy | FLUENT | 3 | March 23, 2012 14:45 |
ATTENTION! Reliability problems in CFX 5.7 | Joseph | CFX | 14 | April 20, 2010 16:45 |
VOF Outlet boundary condition in cfd - ace | JM | Main CFD Forum | 0 | December 15, 2006 09:07 |
what the result is negatif pressure at inlet | chong chee nan | FLUENT | 0 | December 29, 2001 06:13 |
