Turbulence models
Old   September 29, 2013, 18:33
Smile Turbulence models
cesarjets is on a distinguished road
Not sure how I could run the Kepsilon model? I mean I would need to implement a new model? or how I can access to the turbulenceProperties dictionary?
any help on it will be appreciated
thanks much
cesarjets is offline   Reply With Quote
Old   October 16, 2013, 02:08
Bobby
babakflame is on a distinguished road
Hi cesar
If you want to get help; you should declare your problem clearly.
However, If you mean that how could you organize turbulence properties and RAS properties files, these files are in tutorial folder, in reactingFoam tutorial case i.e. counterflow2D.
Bobi
babakflame is offline   Reply With Quote
Old   October 18, 2013, 11:51
Artur's Avatar
Artur
Artur will become famous soon enough
See $FOAM_TUTORIALS/incompressible/simpleFoam/motorbike
Artur is offline   Reply With Quote
different zones, different turbulence models gmwsy FLUENT 5 June 17, 2020 16:42
Y plus for various turbulence models taram CFX 8 December 16, 2013 12:44
Zero Equation Turbulence models stefan.gracik OpenFOAM Programming & Development 3 April 17, 2013 15:12
KOmega Turbulence model from wwwopenFOAMWikinet philippose OpenFOAM Running, Solving & CFD 30 August 4, 2010 11:26
Discussion: Reason of Turbulence!! Wen Long Main CFD Forum 3 May 15, 2009 10:52
