September 28, 2013, 04:38 |
Regarding box keyword in toposet Dict!
Mominul MuKuT
Rep Power: 17 |
To simulate flow induced by plasma actuator solid-fluid domain is necessary, hence in my previous post some foamers suggested me to learn chtMultiRegionFoam/chtmultiRegionSimpleFoam. Today I am practising multi region heat transfer related tutorials, but I don't understand following keyword used in those tutorials.....found in toposet dict.
// Heater { name heater; type cellSet; action new; source boxToCell; sourceInfo { box (-0.01001 0 -100 )(0.01001 0.00999 100); } } I want to know the details about the numbers at right side of box keyword, are they co-ordinates of box of a specific solid/fluid (in example, that box defines a heater)? Thanks in advance. update: I think those are the indication of box co-ordinates, as stated here, if so...then the number '100' is confusing as in blockmeshDict I found the domain size is 0.2X0.08X0.1 (in meter) with 30X10X10 cells in xyz directions. If those are coordinates then 100 (z value) goes outside of domain!!!! |
September 28, 2013, 10:00 |
Nima Samkhaniani
Rep Power: 25 |
those points define two heads of main diameter of box,
so those cell which are placed on this region will be captured as cellSet
My Personal Website (http://nimasamkhaniani.ir/) Telegram channel (https://t.me/cfd_foam) |
September 28, 2013, 10:14 |
Mominul MuKuT
Rep Power: 17 |
September 28, 2013, 10:21 |
Nima Samkhaniani
Rep Power: 25 |
as i said, if you want to define a box! you need to define two points
these points are two heads of main diameter of the box. if you want to define your box in domain , then define these points in domian
September 28, 2013, 10:30 |
#5 | |
Mominul MuKuT
Rep Power: 17 |
box (-0.01001 0 -100 )(0.01001 0.00999 100); so in z direction the box goes outside of domain?? Actually I am confused about the z location of box i.e. -100 t0 100 |
September 28, 2013, 10:38 |
Nima Samkhaniani
Rep Power: 25 |
well Mominul
its OK! consider an imaginary box larger than! domain what happens? nothing special! that part of domain which are in that box are selected!
September 28, 2013, 10:49 |
Mominul MuKuT
Rep Power: 17 |
September 28, 2013, 20:24 |
#8 | |
Mominul MuKuT
Rep Power: 17 |
thanks |
September 29, 2013, 00:36 |
#9 | |
Mominul MuKuT
Rep Power: 17 |
box, multi regions, open foam, simulation, toposet |
[DesignModeler] change/increase model size box | oewnce932c | ANSYS Meshing & Geometry | 5 | April 8, 2022 02:37 |
[snappyHexMesh] HOW to set a circular face by toposet | Jessica | OpenFOAM Meshing & Mesh Conversion | 2 | September 12, 2013 21:54 |
topoSet geometry than more than 1 box | Grimoli | OpenFOAM Pre-Processing | 1 | April 14, 2013 09:54 |
Junction Box | Anil | CFX | 2 | June 27, 2006 11:18 |
Immersol Simulation of a Heated Box | Dong | Phoenics | 0 | March 2, 2006 22:20 |
