September 26, 2013, 07:29 |
Solid-air flow domain
Mominul MuKuT
Rep Power: 17 |
I want to simulate flow induced by plasma actuator. That's why I need to create following geometry as shown below:
How can I define such solid and gas (air) domain? Thanks in advance. |
September 26, 2013, 13:48 |
#2 | |
Jace
Rep Power: 16 |
Anyways, that should at least help you figure out the mesh part. Regards, Jace |
September 26, 2013, 21:19 |
#3 | |
Mominul MuKuT
Rep Power: 17 |
and in /system/topoSetDict the regions are defined in details with co-ordinates, I am reading an explanation about toposet cheers. |
September 27, 2013, 03:47 |
#4 | |
Christoph Kratzsch
Rep Power: 15 |
take a look in the thermophysicalProperties-Dict. If you look in the heatExchanger-tutorial the density for the solid is set to 1000 in the densityCoeff subDict. I don't have used the thermophysicalProperties already, but i think its just an extension of the transportProperties-Dict. Best regards, Christoph |
September 27, 2013, 08:04 |
#5 | |
Mominul MuKuT
Rep Power: 17 |
domains, geometry generation, plasma actuator modeling, pre-processing |
Cross Flow cooling system involving multiple fluids and a solid domain | ajaymenon | CFX | 4 | March 8, 2012 18:00 |
Simulation of a Silo | Attesz | CFX | 20 | October 15, 2010 09:11 |
New topic on same subject - Flow around race car | Tudor Miron | CFX | 15 | April 2, 2004 07:18 |
CFX4.3 -build analysis form | Chie Min | CFX | 5 | July 13, 2001 00:19 |
fluid flow fundas | ram | Main CFD Forum | 5 | June 17, 2000 22:31 |
