cht splitMeshRegion but keeping porous cellZones |
September 24, 2013, 08:51 |
Kapa Lilla
Rep Power: 17 |
Dear All,
I try to simulate conjugate heat transfer with porous zones. Eventually, for cht simulation I use splitMeshRegions to create the different regions which works well, for non-overlapping regions: for exaple FLUID and SOLID. Now, I'd like to have an additional complex cellZone, say COMPLEX, in the fluid zone. How can I do that? If I try to follow the previous procedure, it doesn't work, since COMPLEX is a subset of FLUID. I can delet COMPLEX temporarly and then use splitMeshRegions. I get my two required regions SOLID and FLUID. Now I could copy back the original 3 zone cellZones, but with the splitMeshRegions the regions got a local numbering. Here I'm stucked. What shall I do to have 2 regions, but 3 cellZones? Thanks for any suggestion, Lilla |
September 24, 2013, 16:04 |
#2 | |
Jace
Rep Power: 16 |
September 25, 2013, 04:20 |
Kapa Lilla
Rep Power: 17 |
Unfortunatelly COMPLEX is not marking a fluid zone, but a porous zone. So what kind of fluid is passing by in a time instant is not known. Here I mean, that in the FLUID I have multiphase flow, and FLUID is actually containing COMPLEX and I only want to mark with it cells that defines momentum and heat sources.
Let me post a figure about a simplified test case. Here you can see the FLUID zone and the COMPLEX. In case I separate FLUID and COMPLEX, what kind of boundary conditions shall I use as interface? At the end these boundaries are just interior ones. Of course, for this easy geometry I just redefined by 'topoSet' the COMPLEX cellZone, but in reality I'll have several porous zones in my domain of non-basiy geometries. Thanks, Lilla |
November 19, 2013, 09:32 |
Dear Lilla,
Did you finally solve the problem. Please let me know. Thanks |
cellzones, cht, splitmeshregions |
Porous media setup issues in Fluent | Bernard Van | FLUENT | 29 | January 26, 2017 05:09 |
Modelling Combustion in Porous Zone | tanjinjack | FLUENT | 2 | September 26, 2016 05:10 |
Porous CHT | SAKTI | Siemens | 3 | February 9, 2009 03:05 |
CHT in porous domain? | frank | CFX | 1 | August 26, 2008 17:30 |
porous media: Fluent or Star-CD? | Igor | Main CFD Forum | 0 | December 5, 2002 16:16 |
