Compressible, buoyant BC for porous flow
Old   August 31, 2013, 11:25
Default Compressible, buoyant BC for porous flow
Robert
vainilreb is on a distinguished road
I'm trying to set up a case like seen in the following sketch:
The solver is chtMultiRegionFoam because I've also implemented a thermalMass zone around the tube. Buoyancy is turned off by setting g to zero.
I've tried a lot of things but I always end up with large vortices in the porous zone. Everything worked fine without multi-region in rhoPimpleFoam,
so I guess my BC settings are to blame.
|  \\    /   O peration     | Version:  2.2.0                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
FoamFile
    version     2.0;
    format      ascii;
    class       volScalarField;
    location    "0";
    object      p_rgh;
dimensions      [1 -1 -2 0 0 0 0];
internalField   uniform 101300;
boundaryField
    Front_Plate
        type            zeroGradient;
    End_Plate
        type            zeroGradient;
    Propene_Inlet
        type            zeroGradient;
    Mid_Cylinder
        type            zeroGradient;
    Inner_Quartz_Tube
        type            zeroGradient;
    Probe_Porous_Outlet
        type            fixedMean;
    meanValue    101300;
    value        uniform 101300;
    Probe_Walls
        type            zeroGradient;
    Gas_Mixture_Inlet
        type            zeroGradient;
    flowRegion_to_thermalMass
        type            zeroGradient;
FoamFile
    version     2.0;
    format      ascii;
    location    "0";
    object      p;
boundaryField
    Front_Plate
        type  calculated;
    End_Plate
        type  calculated;
    Propene_Inlet
        type  calculated;
    Mid_Cylinder
        type  calculated;
    Inner_Quartz_Tube
        type  calculated;
    Probe_Porous_Outlet
        type  calculated;
    Probe_Walls
        type  calculated;
    Gas_Mixture_Inlet
        type  calculated;
        type  calculated;
FoamFile
    version     2.0;
    format      ascii;
    class       volVectorField;
    location    "0";
    object      U;
dimensions      [0 1 -1 0 0 0 0];
internalField   uniform (0 0 0);
boundaryField
    Front_Plate
        type            fixedValue;
        value           uniform (0 0 0);
    End_Plate
        type            fixedValue;
    Propene_Inlet
        type            fixedValue;
    Mid_Cylinder
        type            fixedValue;
    Inner_Quartz_Tube
        type            fixedValue;
    Probe_Porous_Outlet
        type            inletOutlet;
        inletValue      uniform ( 0 0 0 );
    Probe_Walls
        type            fixedValue;
    Gas_Mixture_Inlet
        type            uniformFixedValue;
        uniformValue    table
    (0 (0 0 0))
    (1 (2.2366 0 0))
        type            fixedValue;
FoamFile
    version     2.0;
    format      ascii;
    location    "0";
    object      T;
dimensions      [0 0 0 1 0 0 0];
internalField   uniform 293.15;
boundaryField
    Front_Plate
        type            zeroGradient;
    value        uniform 293.15;
    End_Plate
        type            zeroGradient;
    Propene_Inlet
        type            zeroGradient;
    Mid_Cylinder
        type            zeroGradient;
    Inner_Quartz_Tube
        type            zeroGradient;
    Probe_Porous_Outlet
        type            inletOutlet;
        inletValue      $internalField;
    Probe_Walls
        type            zeroGradient;
    Gas_Mixture_Inlet
        uniformValue    table
    (0 293.15)
    (1 443.15)
        type            compressible::turbulentTemperatureCoupledBaffleMixed;
        neighbourFieldName T;
        kappa           fluidThermo;
        kappaName       none;
I'd really appreciate your help. Thanks in advance!
Robert
vainilreb is offline   Reply With Quote
Incompressible and compressible flow. Confused student. Main CFD Forum 27 March 18, 2017 13:25
Compressible flow, no data at the outlet mireis FLUENT 6 September 3, 2015 03:10
Compressible Fluid Flow in COMSOL Multiphysics BBG COMSOL 1 November 19, 2008 15:05
Solving unsteady compressible low speed flow atit Main CFD Forum 8 July 31, 2000 14:19
compressible channel flow.. R.D.Prabhu Main CFD Forum 0 July 17, 1998 18:23
