August 22, 2013, 07:53 |
Taylor Couette Setup and Boundary Conditions
Danesh S
Rep Power: 13 |
Hello Fellow-FOAMers,
I am currently working on a setup for LES of a Taylor Couette flow. To test my setup and mesh, I start out with a laminar simulation (turbulence properties set to laminar). I want to create both laminar couette flow and laminar taylor vortex flow. I use a setup with eta = 0.5, so I have a critical Reynoldsnumber of about 78. The problem is, that I can see vortices on both ends of the cylinder for Reynolds = 50 (smaller than Re_crit) by visualising the y-compinents of velocitiy, like this: Of course for laminar couette flow, there should be no velocities in y-direction. I use icoFoam as laminar solver. Boundary conditions for p are all zeroGradient for innerWall outerWall and upper and lower end. For U all are fixedValue ( 0 0 0 ), just innerWall is rotatingWallVelocity origing (0 0 0) axis (0 1 0) omega 0.004; (rad/s, which leads to 0.002 m/s and Re = 50; viscosity 2e-5) Has anybody got an idea how to improve the setup, or why i get these vortices at low Re? Maybe cyclic BC at top and bottom are necessary? I am grateful for any kind of help! Regards, DaSh |
August 22, 2013, 07:55 |
Danesh S
Rep Power: 13 |
I have tried cyclic BC and symmetryPlane BC, which produces even worse results concerning velocity in y-direction.
Has somebody got an idea, why I see y-Velocity (v) in laminar case with Re smaller Re_crit? Thanks in advance! Danesh |
September 28, 2017, 13:02 |
Did you sort this out?
#3 | |
Lisandro Maders
Rep Power: 13 |
did you sort this out? I am getting Uy values for laminar Couette flow as well using simpleFoam solver.. And also why did you use "rotatingWallVelocity" on inlet BC? Regards, Lisandro |
Symmetry and Periodic boundary conditions | CFD_Fluent_User | FLUENT | 1 | October 16, 2014 03:18 |
An error has occurred in cfx5solve: | volo87 | CFX | 5 | June 14, 2013 18:44 |
FLUENT changes my boundary conditions setup (2D transonic compressor airfoil) | the_knife | FLUENT | 8 | May 27, 2012 20:37 |
how to setup pressure boundary conditions? | bioman6666 | STAR-CCM+ | 4 | April 1, 2011 20:09 |
periodic boundary conditions setup | studentcfd | CFX | 4 | October 25, 2007 02:38 |
