porous simulation
Old   July 31, 2013, 12:08
Default porous simulation
Yuri Frey
yurifrey is on a distinguished road
Hi everyone!
I spent a few days trying to understand how to set up with OF a case which is unsteady, incompressible and laminar flow with a porous medium, but I still have some troubles.
First of all I don't know what solver should I use:
- icoFoam? (from the user guide it seems unable to treat porosity)
- porousSimpleFoam? (it is possible to set laminar? if I put Euler in ddtSchemes does it solve unsteady?)
Second, I made my mesh in Gambit dividing the domain into 2 zones, but when I transform the mesh to OF I don't know how to specify that one of them is a porous medium and to set a Darcy law (in "cellZone" I only have
FoamFile
    version     2.0;
    format      ascii;
    class       regIOobject;
    location    "constant/polyMesh";
    object      cellZones;
0
I am very confused and any help would be very appreciated..
Thank you very much!
Yuri
yurifrey is offline   Reply With Quote
Old   July 31, 2013, 14:41
Lieven
Lieven will become famous soon enough
Hi Yuri,
If you are working with OF 2.2.x Have a look at the pimpleFoam solver in combination with the fvOptions. That should make it possible to combine porosity with transient simulations. You should not do transient simulations with the simple algorithm. The algorithm requires under-relaxation and this is in conflict with proper time integration.
If you have an older version of OF, I'm afraid you will be forced to write your own solver (of course you can do some copy-pasting from this existing ones).
The fact that you have laminar flow is easily accounted for by setting the turbulenceModel to 'laminar'.
Cheers,
L
Lieven is offline   Reply With Quote
Old   August 1, 2013, 06:54
Yuri Frey
Hi Lieven,
thank you very much for your answer. I am using OpenFOAM 2.2.1 so I will try to follow your advice.
But I still have the problem of separating cell zones. In Gambit I have two different zones but when I convert the mesh I lose this information. Do you have any idea of what should I do? Is OF supposed to recognize the zones or should I modify something in cellZones?
Thank you again!
Yuri
Old   August 1, 2013, 07:19
Lieven
Hi Yuri,
I have no experience in working with Gambit in combination with OpenFOAM so I can't really help you with that. I would not start messing around in cellZones (I think you will get lost in its complexity). Maybe Gambit has other options available for identifying cells (cause that's in fact what you are doing) besides defining a 'zone' which are recognized by OF.
Good luck!
Lieven
Old   August 2, 2013, 09:31
Yuri Frey
Thank you anyway Lieven, you've been very helpful. I'm going to try asking in a specific thread in the meshing section.
Yuri
Old   August 4, 2013, 19:02
Yuri Frey
Hi Lieven!
I solved the meshing problem but I still need a little help for the fvOptions part.. These are the first lines of my cellZones file:
FoamFile
    version     2.0;
    format      ascii;
    class       regIOobject;
    object      cellZones;
2
zone2
    type cellZone;
cellLabels      List<label>
500
0
1
I want to set a porous region in zone2, so I create a file named fvOptions into the system folder with
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "system";
    object      fvOptions;
porosity
    type          explicitPorositySource;
    active        yes;
    selectionMode cellZone;
    cellZone      zone2;
    explicitPorositySourceCoeffs
        type DarcyForchheimer;
        DarcyForchheimerCoeffs
              d    d [0 -2 0 0 0 0 0] (5e7 -1000 -1000);
              f    f [0 -1 0 0 0 0 0] (0 0 0);
              coordinateSystem
                  e1    (1 0 0);
                  e2    (0 1 0);
but it doesn't work.. I tried to change the coefficients, but everything remains the same, so I think OpenFOAM doesn't read the fvOptions file at all. I don't understand why..
Thank you again for your help,
Yuri
Old   August 4, 2013, 19:19
Lieven
Hi Yuri,
I'm sorry to say that I can't help you with this. I'm still using version 2.1.x which doesn't use the fvOptions thing. So I hope someone else can assist you in setting this up properly.
Cheers,
L
Old   August 5, 2013, 05:40
Yuri Frey
Thank you Lieven, I will try again in a specific thread.
Yuri
fluent 2D axisymmetric with swirl simulation with porous media user0314 FLUENT 1 June 11, 2015 03:57
Porous Region within Open Air "Wind Tunnel" Region Interfacing pkirchner STAR-CCM+ 10 March 27, 2014 20:10
porous medium simulation in openfoam subhsngh OpenFOAM Running, Solving & CFD 0 June 26, 2013 09:04
simplified paralle tube bundle simulation (porous domain) Benfa CFX 1 May 5, 2013 09:01
Simulation of incompressible flow in porous medium Jack Main CFD Forum 7 February 16, 2000 12:27
