Blockmesh problem with more than one block
Old   June 4, 2013, 16:48
Default Blockmesh problem with more than one block
Sven Degner
sven82 is on a distinguished road
Hello Foamers
I have some trouble with blockmesh,
The case has 3 blocks, with direct connection,
same size in x,y,z direction.
blockMesh -> works well,
but in the result, blockmesh generates a patches between the blocks,
but I would like to have only on block, with no patches between the blocks,
like interfaces!
hope anyone got a idea,
Thanks alot,
Sven
my blockMesh case:
| \\ / O peration | Version: 2.1.x |
| \\ / A nd | Web: www.OpenFOAM.org |
| \\/ M anipulation | |
FoamFile
version 2.0;
format ascii;
class dictionary;
object blockMeshDict;
convertToMeters 0.001;
vertices
(1688.67551264726 3506.57083387458 -1984) // Vertex 0 = 0
(1688.67551264726 3506.57083387458 1984) // Vertex 1 = 1
(1688.67551264726 3506.57083387458 1984) // Vertex 2 = 2
(1688.67551264726 3506.57083387458 -3984) // Vertex 3 = 3
(1688.67551264726 3506.57083387458 -1984) // Vertex 4 = 4
(1688.67551264726 3506.57083387458 3984) // Vertex 5 = 5
(137.107261561288 284.706162257032 -1984) // Vertex 6 = 6
(137.107261561288 284.706162257032 -3984) // Vertex 7 = 7
(137.107261561288 284.706162257032 3984) // Vertex 8 = 8
(137.107261561288 284.706162257032 1984) // Vertex 9 = 9
(137.107261561288 284.706162257032 -1984) // Vertex 10 = 10
(137.107261561288 284.706162257032 1984) // Vertex 11 = 11
(-137.107261561288 284.706162257032 1984) // Vertex 12 = 12
(-137.107261561288 284.706162257032 -1984) // Vertex 13 = 13
(-137.107261561288 284.706162257032 1984) // Vertex 14 = 14
(-137.107261561288 284.706162257032 3984) // Vertex 15 = 15
(-137.107261561288 284.706162257032 -3984) // Vertex 16 = 16
(-137.107261561288 284.706162257032 -1984) // Vertex 17 = 17
(-1688.67551264726 3506.57083387458 -1984) // Vertex 18 = 18
(-1688.67551264726 3506.57083387458 1984) // Vertex 19 = 19
(-1688.67551264726 3506.57083387458 1984) // Vertex 20 = 20
(-1688.67551264726 3506.57083387458 3984) // Vertex 21 = 21
(-1688.67551264726 3506.57083387458 -3984) // Vertex 22 = 22
(-1688.67551264726 3506.57083387458 -1984) // Vertex 23 = 23
blocks
hex (13 18 19 12 10 0 1 11) rotor (20 20 20 ) simpleGrading (1 1 1)
hex (14 20 21 15 9 2 5 8) rotor (20 20 20) simpleGrading (1 1 1)
hex (16 22 23 17 7 3 4 6) rotor (20 20 20) simpleGrading (1 1 1)
edges
arc 0 18 ( 0.0 3892.0 -1984)
arc 1 19 ( 0.0 3892.0 1984)
arc 10 13 ( 0.0 316.0 -1984)
arc 11 12 ( 0.0 316.0 1984)
arc 2 20 ( 0.0 3892.0 1984)
arc 5 21 ( 0.0 3892.0 3984)
arc 9 14 ( 0.0 316.0 1984)
arc 8 15 ( 0.0 316.0 3984)
arc 3 22 ( 0.0 3892.0 -3984)
arc 4 23 ( 0.0 3892.0 -1984)
arc 7 16 ( 0.0 316.0 -3984)
arc 6 17 ( 0.0 316.0 -1984)
boundary
left_rot
type cyclic;//patch;
neighbourPatch right_rot;
faces ((10 0 1 11));
transform rotational;//unknown;
rotationAxis (0 0 1);
rotationCentre (0 0 0);
matchTolerance 0.001;
right_rot
neighbourPatch left_rot;
faces ((13 18 19 12));
left_top
neighbourPatch right_top;
faces ((7 3 4 6));
right_top
neighbourPatch left_top;
faces ((16 22 23 17));
left_bottom
type cyclic;
neighbourPatch right_bottom;
faces ((9 2 5 8));
right_bottom
type cyclic;
neighbourPatch left_bottom;
faces ((14 20 21 15));
inlet
type patch;
faces ((2 5 21 20)(3 4 23 22));
outlet
type patch;
faces ((0 1 19 18));
shaft
type wall;//patch;
faces ((7 6 17 16)(8 9 14 15)(10 11 12 13));
mergePatchPairs
sven82 is offline   Reply With Quote
Old   June 4, 2013, 18:08
Lieven
Lieven will become famous soon enough
Hi Sven,
You should not define points multiple times. E.g. vertex 1 and 2 are exactly the same point. So instead of defining it twice and using '1' and '2' in the definition of the blocks, you should only define it once, e.g. as '1', and refer to this point whenever you need in the block. This way blockmesh will automatically recognize the internal connections between the blocks (and not create a patch for it).
I hope my explanation is clear, if not, just say so :-).
Cheers,
Lieven
Lieven is offline   Reply With Quote
[ICEM] A challenging problem about "convert block type" Xeder ANSYS Meshing & Geometry 0 July 25, 2012 08:46
[blockMesh] Problem with blockMesh boundaries Elise OpenFOAM Meshing & Mesh Conversion 2 May 8, 2012 06:56
foamLog not solving for Ux, Uy, Uz aerospain OpenFOAM Post-Processing 5 April 18, 2012 11:01
Easy problem - blockMesh dipling OpenFOAM 13 July 27, 2009 08:19
Bug in blockMesh feymark OpenFOAM Bugs 8 March 24, 2009 23:11
