April 11, 2013, 00:36 |
topoSet geometry than more than 1 box
Gabriel de PInho RImoli
Rep Power: 13 |
Is there a way to add more than 1 box on a topoSet geometry??Im trying to do a geometry like this,but im failing all the time =/
What should I do?? cellSet heater new boxToCell (0 4 10)(20 16 15) cellSet heater add boxToCell (0 4 15)(20 4.5 15.5) cellSet heater add boxToCell (0 5 15)(20 5.5 15.5) cellSet heater add boxToCell (0 6 15)(20 6.5 15.5) cellSet heater add boxToCell (0 13.5 15)(20 14 15.5) cellSet heater add boxToCell (0 14.5 15)(20 15 15.5) cellSet heater add boxToCell (0 15.0 15)(20 16 15.5) cellZoneSet heater new setToCellZone heater cellSet leftSolid new boxToCell (0 0 10 )(20 4 15) cellZoneSet leftSolid new setToCellZone leftSolid cellSet rightSolid new boxToCell (0 16 10 )(20 20 15) cellZoneSet rightSolid new setToCellZone rightSolid cellSet bottomAir new boxToCell (0 0 0 )(20 20 10) cellZoneSet bottomAir new setToCellZone bottomAir cellSet topAir clear cellSet topAir add cellToCell heater cellSet topAir add cellToCell leftSolid cellSet topAir add cellToCell rightSolid cellSet topAir add cellToCell topAir cellSet topAir invert cellZoneSet topAir new setToCellZone bottomAir Last edited by Grimoli; April 11, 2013 at 01:27. |
April 14, 2013, 09:54 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Greetings Gabriel,
Do you mean setSet? Because those commands are for setSet, not topoSet I took a look at the tutorial "heatTransfer/chtMultiRegionFoam/multiRegionHeater" and I think I understand your confusion. It still has the file "makeCellSets.setSet", but the tutorial actually uses topoSet instead, which relies on the dictionary file "system/topoSetDict". To use, you must run setSet like this: Code:
setSet -batch makeCellSets.setSet Code:
setSet -help Bruno
problem when imported geometry from 3D CAD to star ccm, | TAREK GANAT | STAR-CCM+ | 1 | May 21, 2013 23:15 |
Problem Importing Geometry ProE to CFX | fatb0y | CFX | 3 | January 14, 2012 20:42 |
[snappyHexMesh] Irregular mesh generation for simple box geometry | ajl42 | OpenFOAM Meshing & Mesh Conversion | 0 | March 7, 2011 18:04 |
[snappyHexMesh] SnappyHexMesh meshes inside and outside of an STL geometry | villier | OpenFOAM Meshing & Mesh Conversion | 17 | June 15, 2010 20:51 |
Incorrect geometry file name | Fabián Betancourt | Phoenics | 3 | March 15, 2006 09:36 |
