Drag coefficent and Drag force
Old   March 8, 2013, 17:55
Default Drag coefficent and Drag force
Daniel
DanoGC is on a distinguished road
I'm trying to calculate the drag coefficent and drag force on a sphere with diameter 500mm (I'm using mm as measure). My fluid is water and the Reynold coefficient is Re=0.025 and the velocity is 5.0E-5 because I need a laminar behaviour in my simulation and I used the code to put in the controlDict file. The problem that I have is the results of the drag coefficent is very big, like 1.3E+11. I'm don't know what is happenig because I have reviewed all data.
If somebody can help me, it would be terrific.
DanoGC is offline   Reply With Quote
Old   March 22, 2013, 05:28
Ilya
skeptik is on a distinguished road
If you have physically reasonable pressure distribution, just check Aref and Lref in forceCoeffs section of your controlDict.
Or show controlDict here at least.
practice makes perfect
skeptik is offline   Reply With Quote
Airfoil negative drag coefficent James Forrest Main CFD Forum 9 September 5, 2022 11:30
question on drag coefficent hippolyte Main CFD Forum 0 April 19, 2011 01:37
convergence criteria by lift and drag coefficent xtof CFX 3 March 18, 2011 15:38
Coefficent of Drag jd210 OpenFOAM Running, Solving & CFD 0 March 8, 2011 20:34
about the drag coefficient maximus Main CFD Forum 7 April 18, 2005 20:00
