Mesh export to OpenFOAM issue
Old   March 2, 2013, 11:42
Default Mesh export to OpenFOAM issue
starter
sihaqqi is on a distinguished road
Hi All
When I convert my fluent.msh file to OpenFOAM using fluent3DMeshtoFoam, files are generated succesfully in polyMesh withut any errors but my geometry in paraFoam completely changes. File 1 shows two pipes connected by a 90degree mitre drawn half in symmetry in Ansys and file 2 shows geometry in openFoam which is only a rectangle. Can anyone advise.
Many thanks
Regards
sihaqqi is offline   Reply With Quote
Old   March 2, 2013, 15:07
Chrisi1984 is on a distinguished road
I think you just activated "outline" in Paraview. Swith that button to "surface"
then you will see your real geometry that should look as it does in ANSYS.
Regards
Chrisi
Chrisi1984 is offline   Reply With Quote
Old   March 2, 2013, 23:14
starter
Thanks Chrisi. Problem solved. This is what happens when you are a beginner.
Regards
geometry import, mesh export issues
[Other] vtk mesh or Abaqus mesh to OpenFOAM bigphil OpenFOAM Meshing & Mesh Conversion 27 November 23, 2015 18:31
[Commercial meshers] .CCM to OpenFoam mesh issue otq OpenFOAM Meshing & Mesh Conversion 6 January 8, 2013 11:57
[Gmsh] 2D Mesh Generation Tutorial for GMSH aeroslacker OpenFOAM Meshing & Mesh Conversion 12 January 19, 2012 04:52
Export 2D mesh from ICEM to Fluent BuilttoSpill ANSYS Meshing & Geometry 4 August 28, 2010 09:16
