Contact angle between different phase and wall
Old   March 1, 2013, 00:48
Default Contact angle between different phase and wall
Guifan Li
liguifan is on a distinguished road
Good evening,
I am trying to simulating a droplet made of oil drop into a water base.
However, I am confusing about setting up the Contact Angle between phase and between phase and wall.
for example
boundaryField
sideWall
type alphaContactAngle;
thetaProperties
( water air ) 90 0 0 0
( oil air ) 90 0 0 0
( water oil ) 90 0 0 0
value uniform 1;
lowerWall
thetaProperties
value uniform 0;
like in the sideWall, there are (water air) 90 0 0 0. I understand the contact angle between water and air is 90 here. But in lowerWall section, there is also (water air) 90 0 0 0. what is the difference between these two (water air)? and how can I set up the contact angle between the water and the wall? (in the breakdam-one phase, I can successfully set up the contact angle between water and wall but here is a little bit different).
Can anyone give me some suggestions please?
liguifan is offline   Reply With Quote
Old   March 7, 2013, 03:46
Michiel
michielm is on a distinguished road
The second water-air is on a different patch (lowerWall as opposed to sideWall) because you can set the contact angle on each patch individually to be able to model a real-life situation in which maybe one wall is wetting with respect to the water and another wall is non-wetting (think of a glass lid and a teflon wall in a cooking pan for example).
Setting up the contact angles with the walls is just a matter of changing the 90s into something else. So to give an example: if you set the following:
lowerWall
        thetaProperties
            ( water air ) 50 0 0 0
            ( oil air )120 0 0 0
That means that a water-air interface will have a contact angle of 50 with the lowerWall, an oil air interface will have a contact angle of 120 with the lowerWall and the water oil interface will have a 90 degree contact angle.
I am not that familiar with the multiPhaseInterFoam so I don't know what the 3 zeros in the boundaryField settings mean, but they seem like dummy variables to me. To confirm that you would have to dig into the solver code a bit.
michielm is offline   Reply With Quote
Natural convection in a closed domain STILL NEEDING help! Yr0gErG FLUENT 4 December 2, 2019 01:04
Slug Flow, interFoam, problems with Contact Angle PrzemekPL OpenFOAM Running, Solving & CFD 13 February 18, 2014 23:10
Water subcooled boiling Attesz CFX 7 January 5, 2013 04:32
help with UDF for contact angle based on contact line velocity gandesk Fluent UDF and Scheme Programming 14 October 29, 2012 14:58
angle for wall adhesion in two phase flow Al-jasim FLUENT 0 August 18, 2007 11:04
