Boundary Conditions on a Sphere
Old   December 6, 2012, 06:34
Default Boundary Conditions on a Sphere
VS
VSass is on a distinguished road
Pals,
i want to apply a BC for velocity on a sphere. I want the velocity ALWAYS to be tangent on the faces of the sphere and never,during the solution, going through its surface.
Does anybody know which BC i should apply?
VSass is offline   Reply With Quote
Old   December 7, 2012, 04:42
Tom Fahner
tomf will become famous soon enoughtomf will become famous soon enough
Send a message via MSN to tomf Send a message via Skype™ to tomf
Hello VSass,
It depends whether your sphere should be moving (movingMesh) or if it is only rotating in a stationary point. I am assuming it is the latter, in that case you can use:
rotatingWallVelocity
If it is the former:
movingWallVelocity
Depending on the choice you may need to set some other parameters that describe the motion.
Regards,
Tom
tomf is offline   Reply With Quote
Old   December 7, 2012, 04:47
VS
Thanks Tomf,
i have a fixed sphere so i guess i sould work with the rotatingWallVelocity.
Good day to you
Old   December 7, 2012, 07:44
Bernhard
Bernhard is on a distinguished road
I am not sure what you are trying to model, but you could also consider slip as boundary condition.
Bernhard is offline   Reply With Quote
Old   December 7, 2012, 10:46
VS
Bernhard,
i have a hybrid sphere seperated in two boundaries, upstream and downstream, and this hybrid sphere is located inside a farfield which is also spherical and we suppose it is far away from our hybrid sphere. I am trying to solve the Navier - Stokes equations in the hybrid sphere using icoFoam,but Courant number keeps crashing no matter what time step i apply. I now work on modified icoFoam in order to keep e.g. maxCo=0.7,but i want to be sure that the crash is not due to boundary conditions.
boundary conditions, pre-processing
mesh file for flow over a circular cylinder Ardalan Main CFD Forum 7 December 15, 2020 14:06
Domain Imbalance HMR CFX 5 October 10, 2016 06:57
Impinging Jet Boundary Conditions Anindya Main CFD Forum 25 February 27, 2016 13:58
Concentric tube heat exchanger (Air-Water) Young CFX 5 October 7, 2008 00:17
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues michele OpenFOAM Meshing & Mesh Conversion 2 July 15, 2005 05:15
