Setting up Case for different turbulence models with buoyancy-driven flow
Old   November 19, 2012, 05:15
Default Setting up Case for different turbulence models with buoyancy-driven flow
Markus Trompa
MisterX is on a distinguished road
Hello foamers,
I am new to OF (OpenSuse 12.1 + OF-2.1.1) and write my masterthesis on it.
At the moment I am setting up cases for turbulent flows in a room (inlet + outlet + obstacle), in which the obstacle has a heat flux and the inlet a constant flow rate.
I want to simulate this case with different turbulence models and compare the results whicht fits best to measured data.
Now, I am little stuck on pre-processing in finding the right solver and BC's to handle this problem.
The BC's for U and p are no problem, and for T I used zeroGradient at the walls, at inlet fixedValue and for outlet inletOutlet. For the walls of the obstacle I defined a turbulentHeatFluxTemperature (heat source: power).
Now my question is, what kind of solver suits best for this case and do I have to define alphaEff (kappaEff) and Cp or is kappaEff only defined by nu/Pr + nut/Prt in transportProperties and Cp could be easily defined by CP = 1000?
In advance thank you very much for help.
Markus
MisterX is offline   Reply With Quote
Old   November 19, 2012, 06:10
Markus Trompa
In addition, the temperature of the inlet flow is 293K and the heat source is 700W which leads to 313K on the surface of the obstacle.
The fluid medium is air and I run simulation for imcompressible fluid (neglect dependence of density).
I want to handle the case transient.
I think there are mainly two possibilities: a) pisoFoam and include enthalpy equation or b) buoyantBoussinesqPimpleFoam
bcs, buoyancy flow, solver, turbulentheatflux
An error has occurred in cfx5solve: volo87 CFX 5 June 14, 2013 18:44
operating density in buoyancy driven flow Marie-Anne Main CFD Forum 2 March 24, 2006 10:52
Why Turbulence models are not universal. Senthil Main CFD Forum 4 July 5, 2000 05:34
fluid flow fundas ram Main CFD Forum 5 June 17, 2000 22:31
buoyancy driven flow Jannis Dotsikas Main CFD Forum 3 October 9, 1998 09:24
