Boundary conditions for a free surface flow using interfoam
Old   November 4, 2012, 04:35
Question Boundary conditions for a free surface flow using interfoam
Oleg
FrolovOY is on a distinguished road
HI all! I simulate flow in a channel with a free surface using interfoam solver. For this purpose I built a channel with length of 10 meters, width of 2 meters. For the velocity, pressure and alpha asked the following boundary conditions:
FoamFile
    version     2.0;
    format      ascii;
    class       volVectorField;
    object      U;
dimensions      [0 1 -1 0 0 0 0];
internalField   uniform (0 0 0);
boundaryField
    inlet
        type            fixedValue;
        value           uniform (1 0 0);
    outlet
        type            zeroGradient;
    upperWall
        type            fixedValue;
        value           uniform (0 0 0);
    lowerWall
        type            fixedValue;
    frontAndBack
        type            empty;
FoamFile
    version     2.0;
    format      ascii;
    class       volScalarField;
    object      p_rgh;
dimensions      [1 -1 -2 0 0 0 0];
internalField   uniform 0;
boundaryField
    inlet
        type            zeroGradient;
    outlet
        type            totalPressure;
        p0              uniform 0;
        U               U;
        phi             phi;
        rho             rho;
        psi             none;
        gamma           1;
        value           uniform 0;
    upperWall
        type            zeroGradient;
    lowerWall
        type            zeroGradient;
    frontAndBack
        type            empty;
FoamFile
    version     2.0;
    format      ascii;
    object      alpha;
dimensions      [0 0 0 0 0 0 0];
boundaryField
    inlet
         type            fixedValue;
         value           uniform 1;
    outlet
        type            zeroGradient;
    upperWall
        type            zeroGradient;
    lowerWall
        type            zeroGradient;
    atmosphere
        type            inletOutlet;
        inletValue      uniform 0;
        value           uniform 0;
    frontAndBack
        type            empty;
The geometry of the fluid is defined as follows:
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "system";
    object      setFieldsDict;
defaultFieldValues
    volScalarFieldValue alpha1 0
regions
    boxToCell
        box (0 0 0) (2 2 1);
        fieldValues
            volScalarFieldValue alpha1 1
However, as seen in the following figure 1, the problem arises in that the channel width from 0 to 2 meters is not completely filled. In other words, alfa1 must equal 1 throughout the width of the section to the left of the front of the free surface.
Нow can I fix it? What I asked wrong in the boundary conditions?
Thanks!
Regards, FrolovOY
FrolovOY is offline   Reply With Quote
Old   January 7, 2013, 10:27
Albrecht vBoetticher
vonboett is on a distinguished road
Hi FrolovOY,
could you tell what cell size you apply, and maybe post your transportProperty file?
The surface between air and liquid depends on the grid and on the transportProperties...
vonboett is offline   Reply With Quote
Old   January 10, 2013, 09:59
Oleg
Originally Posted by vonboett View Post
Hi FrolovOY,
Hi, vonboett. This is my transportProperty:
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "constant";
    object      transportProperties;
phase1
    transportModel  Newtonian;
    nu              nu [ 0 2 -1 0 0 0 0 ] 10;
    rho             rho [ 1 -3 0 0 0 0 0 ] 1000;
    /*CrossPowerLawCoeffs
        nu0             nu0 [ 0 2 -1 0 0 0 0 ] 1e-06;
        nuInf           nuInf [ 0 2 -1 0 0 0 0 ] 1e-06;
        m               m [ 0 0 1 0 0 0 0 ] 1;
        n               n [ 0 0 0 0 0 0 0 ] 0;
    BirdCarreauCoeffs
        nu0             nu0 [ 0 2 -1 0 0 0 0 ] 0.0142515;
        k               k [ 0 0 1 0 0 0 0 ] 99.6;
        n               n [ 0 0 0 0 0 0 0 ] 0.1003;
phase2
    nu              nu [ 0 2 -1 0 0 0 0 ] 1.48e-5;
    rho             rho [ 1 -3 0 0 0 0 0 ] 1;
    BirdCarreauCoeffs
sigma           sigma [ 1 0 -2 0 0 0 0 ] 0.07;
and blockMeshDict file:
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      blockMeshDict;
convertToMeters 1;
vertices
    (0 0 0)
    (10 0 0)
    (0 2 0)
    (10 2 0)
    (0 0 1)
    (10 0 1)
    (0 2 1)
    (10 2 1)
blocks
    hex (0 1 3 2 4 5 7 6) (100 20 10) simpleGrading (1 1 1)
edges
boundary
    inlet
        type patch;
        faces
            (0 4 6 2)
    outlet
        type patch;
        faces
            (1 5 7 3)
    upperWall
        type wall;
        faces
            (2 3 7 6)
    lowerWall
        type wall;
        faces
            (0 1 5 4)
    frontAndBack
        type empty;
        faces
            (0 1 3 2)
            (4 5 7 6)
mergePatchPairs
In such a way ten cells form one meter.
I would be grateful for your help.
Thanks!
Regards, FrolovOY
Old   January 11, 2013, 03:21
Daniele Vicario
danvica is on a distinguished road
Hi Frolov,
why you have such a high kinematic viscosity for alpha1 ?
phase1
Regards,
Daniele Vicario
blueCFD2.1 - Windows 7
danvica is offline   Reply With Quote
Old   January 11, 2013, 12:31
Michiel
michielm is on a distinguished road
There is two things that come to mind:
- have you tried using -1 to 3 instead of 0 to 2 in the setFieldsDict? Maybe the fact that you put it exactly on the boundary is the issue
- the other thing is indeed the extremely high viscosity (10000 Pas so 1E8 bigger than that of water) which might cause excessive wall drag therefore causing a sort of vena contracta type of behaviour
Edit: given the other properties you use I guess you meant to use the (kinematic) viscosity of whether. Which is 1e-6
michielm is offline   Reply With Quote
Old   January 21, 2013, 02:25
Oleg
Originally Posted by danvica View Post
Hi Frolov,
Regards,
Hi danvitsa. For alpha1 given such a large kinematic viscosity, because I'm trying to simulate a polymer flow in the channel. For example, High-density polyethylene (HDPE). Such polymers are characterized by high dynamic viscosity, namely 10e3 - 10e5 Pa * sec. Accordingly, the kinematic viscosity is set from 1 to 100 m2/sec.
Old   January 21, 2013, 02:59
Oleg
Hi michielm.
Following your advice, I expanded setFields borders on Y ((-1 -1 0) (3 4 1) , but it did not help.
Liquid with small kinematic viscosity (eg water) behaves well. See Figure 1. (Nu = 1.3 * 10e-6; deltaX = 0.05 m)
Figure 2 shows the flow of fluid with a high kinematic viscosity without gravity.
It is seen that during the motion between the fluid and the wall is formed air. But it is given no-slip condition?
upperWall
        type            fixedValue;
    lowerWall
        type            fixedValue;
Maybe there are other settings in the boundary conditions that need to be considered?
Maybe to simulate motion of polymers or similar to them, there is another solver rather than interfoam?
How can I set the phase1 parameters (in my case, HDPE) for the non-Newtonian fluid in a file transportProperties? May be it is necessary to ask the contact angle in alpha1 file?
Old   January 21, 2013, 05:51
No slip means that at your boundary nothing moves, so it might be the air cant be pushed away here, although I didn't face that problem in my simulations. With low viscosity your cell center at the boundary probably gets an alpha1 value of liquid due to the high possible gradient in the phase interface, so you won't see the air in your longitudinal sections, but maybe you could check this if you look at the boundary itself in paraview, colored by cell values of alpha1, not by interpolated values.
The other more reasonable explanation would be that because you have no gravity there is no buoyancy to move the air upwards from the lower boundary, which could be the reason for the difference between your two simulations.
Old   January 25, 2013, 06:27
Michiel
No slip means that at your boundary nothing moves, so it might be the air cant be pushed away here, although I didn't face that problem in my simulations.......
Indeed this is a well-known problem in fluid dynamics of moving contact lines. With a perfectly sharp interface it would be impossible for the fluid-fluid interface to move at the wall, because of the no-slip condition. However, with VOF this is automatically solved because the alpha1 field in cells at the boundary can still be advected as long as the viscous stress allows it and the contact line location is adjusted according to that field, therefore removing the issue of a non-mobile contact line.
That said, for a sharp interface the viscous stress diverges at the contact line because of the no-slip condition and the rate of divergence is obviously worse when the viscosity of the fluid is higher. Therefore it might be (I am guessing a bit here), that the very high viscosity of your fluid causes the contact line to remain immobile, despite the diffuse interface.
What you could try to get rid of the stress singularity is to use a navier slip BC to see if that indeed makes the contact line mobile.
[EDIT] for a first try you can use the partialSlip BC, if it indeed works you can always implement the navier slip BC for more `logical' behaviour
boundary conditions, channel flow, free surface, interfoam
Wind turbine simulation Saturn CFX 60 July 17, 2024 06:45
3-D Compressible Flow Boundary Conditions Tyler FLUENT 4 February 5, 2009 20:58
New topic on same subject - Flow around race car Tudor Miron CFX 15 April 2, 2004 07:18
Please help with flow around car modelling! Tudor Miron CFX 17 March 19, 2004 20:23
free surface boundary conditions Gerard Moroney Main CFD Forum 2 November 17, 1998 16:49
