spatial non uniform boundary conditions
Old   October 26, 2012, 11:53
Default spatial non uniform boundary conditions
pepe.aero is on a distinguished road
Hi all,
i'm looking for the proper way in order to assign spatially non-uniform boundary condition at the inflow side. For example, a parabolic velocity profile varying along z (vertical) axis.
The condition is steady in time.
Can anyone give me a suggestion about what is the best type of BCs to choose in order to do it?
Thanks all for the support.
Regards,
Andrea
pepe.aero is offline   Reply With Quote
Old   October 29, 2012, 04:34
ngj
Niels Gjoel Jacobsen
ngj will become famous soon enoughngj will become famous soon enough
Hi Andrea,
In that case, I would suggest that you start by looking at swak4Foam, where you can specify e.g. algebraic expressions: http://openfoamwiki.net/index.php/Contrib/swak4Foam .
If you search for swak4Foam on the forum, you will find many threads describing its usage.
Kind regards,
Niels
ngj is offline   Reply With Quote
Old   October 29, 2012, 13:42
Hi Niels,
thank you for your reply.
In fact, I'm taking a look to skaw4foam...but it's not clear to me if is possible to assign non uniform condition by points (and then the solver interpolates the velocity profile in the missing points) or just by algebrical expressions.
Can you answer to this question?
Thanks you so much for your support.
Regards,
Andrea
Old   October 29, 2012, 15:41
ngj
Hi Andrea,
No, I have never used swak4Foam.
Good luck,
Niels
Old   November 12, 2012, 10:29
Duong A. Hoang
duongquaphim is on a distinguished road
Send a message via Yahoo to duongquaphim
I think groovyBC is quite a good tool for this purpose (http://openfoamwiki.net/index.php/Contrib_groovyBC). I used that before and it works well.
Duong
duongquaphim is offline   Reply With Quote
boundary condition, non uniform, parabolic inlet, spatial, type
How to set uniform heating boundary condition? Sargam05 OpenFOAM 0 September 11, 2012 11:09
Need help with boundary conditions: open to atmosphere Wolle OpenFOAM 2 April 11, 2011 08:32
Pressure instability with rhoSimpleFoam daniel_mills OpenFOAM Running, Solving & CFD 44 February 17, 2011 18:08
Boundary condition setting for non-premixed combustion using reactingFoam skyopener OpenFOAM 0 May 23, 2010 23:55
A problem about setting boundary conditions lyang Main CFD Forum 0 September 19, 1999 19:29
