variable pressure at the output of a manifold |
September 26, 2012, 12:11 |
Joe
I'm actually simulating a car intake manifold. I've solved it with constant BC, but I would like to do it with a variable outlet pressure as an engine aspiration. Is there any function simulating an engine aspiration or something to define a variable output pressure? I guess there is something to do that, I've find things but they didn't clearly solve my needs or explain how to use them. I'm sorry, I'm new in OpenFOAM and I just know how to use basic solvers If that helps, I've done the mesh with snappyHexMesh and solved as an incompressible flow (pisoFoam). I just know inlet and outlet pressure (wich is variable), but not velocity, I've solved the initial velocity conditions with potentialFoam Thank you very much. regards |
variable pressure |
"Pressure Inlet" Boundary Setup | Wijaya | FLUENT | 15 | May 18, 2016 10:08 |
UDF to define or adjust pressure??? | engahmed | FLUENT | 0 | July 6, 2010 17:19 |
Pressure Rise Error | emueller | CFX | 0 | May 5, 2009 11:08 |
Variable outside pressure | Neser25 | CFX | 9 | June 5, 2006 12:37 |
Hydrostatic pressure in 2-phase flow modeling (CFX4.2) | HB &DS | CFX | 0 | January 9, 2000 13:19 |
