BC for a permeable internal wall
Old   April 20, 2012, 05:54
Default BC for a permeable internal wall
QPK
Andi-HH is on a distinguished road
is it possible to define such a BC for an internal wall (permeable to thewhole current)?
Or is it possible to merge the internal wall with the internal mesh so that it is just no wall anymore?
I am thankful for any help!
Andi
Andi-HH is offline   Reply With Quote
Old   April 23, 2012, 05:22
kid
cfdkid
kid is on a distinguished road
Well should not you use InletOutlet .
kid is offline   Reply With Quote
Old   April 23, 2012, 06:33
QPK
InletOutlet didn't seem to work, maybe I will give it another try...
Old   April 23, 2012, 07:18
kid
cfdkid
Hello have you tried tutorial case on Porosity.
incompressible/porousSimpleFoam
specially the folder in anyCase/constant/porousZones file.
Have a look in it.
Regards
CFDkid
Old   April 24, 2012, 07:34
QPK
Hi kid,
my porous zone is fine, my problem is just the internal wall (unfortunately it needs to be there).
Old   April 24, 2012, 07:55
kid
cfdkid
Have you tried "empty " type BC.
________________________________________
Regards,
CFDkid
It never gets easier You just get Better
Old   April 24, 2012, 11:39
QPK
Thanks for the reply!
I think I solved it with cyclic.
In my case the "internalWall" had a copy "internalWall_BACK" and with a cyclic connection everything is fine.
internal, permeable, wall
[ANSYS Meshing] Remove Internal wall matteoL ANSYS Meshing & Geometry 2 November 30, 2011 05:45
[ICEM] Export ICEM mesh to Gambit / Fluent romekr ANSYS Meshing & Geometry 1 November 26, 2011 13:11
volume flow through internal hole in the wall wouter OpenFOAM 4 February 14, 2011 08:36
Influece of wall velocity in the main flow marvin CFX 0 March 22, 2008 03:05
deleting internal wall HK CFX 1 March 16, 2007 09:54
