April 16, 2012, 16:56 |
foamLog not solving for Ux, Uy, Uz
Hi all,
I recently re-installed OpenFOAM due to a major cock-up after some installation gone wrong, and I am not getting the same behaviour from OF as I had before. I also lost my home folder with all the cases I had run for the last two months. Right now, when I run simple, pimple or piso (FOAM) it doesn't "solve for Ux" (or Uy or Uz) So, I cannot plot them either after running foamLog on the log file created during the run. I have been reviewing the tutorials to check for any hints in the fvSchemes and/or fvSolutions files without any luck. Could someone give me a hand, please? Thanks! |
April 16, 2012, 17:12 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Hi aerospain,
Something very strange is going on there. Does it not work with any tutorial at all? Not even the very first we learn about on the User Guide, the "incompressible/icoFoam/cavity"? The only files that I can remember that might be impairing functionality would be located in the semi-hidden folder "~/.OpenFOAM". If you remove or rename that folder, you might be able to make things work as intended once again. Best regards, Bruno
April 16, 2012, 19:51 |
Hello Bruno,
That .OpenFOAM hidden directory doesn't exist in my user's home folder. I have double-checked the cavity tutorial and the velocity components convergence history is reported during the simulation. I may have messed up when looking at different files in the tutorials to build up my case. Let me describe it in case you could provide some hints: incompressible k-epsilon simulation with one inlet (-x), one outlet (+x), symmetry on y (for now) with 'empty' BC, and top/bottom z with slip wall, symmetry, cyclic or other BC. At z+-0.5 there is a cylinder aligned axially with the flow, therefore 'wall' condition. The base of this cylinder is 1m and my velocity is 0.1m/s. I will be starting with Re number below. If worse comes to worst, is there a robust way to uninstall OpenFOAM from my Ubuntu 11.10 completely before I re-install it again. Regards, Carlos |
April 17, 2012, 04:25 |
#4 | |
Bruno Santos
Rep Power: 128 |
Hi Carlos,
Best regards, Bruno
April 17, 2012, 11:41 |
Hi Bruno,
Sorry for my badly made question from last night. I wasn't expecting anyone to 'waste' time explaining that issue. I forgot to mention that I used the 'sudo apt-get install ..." procedure for Ubuntu. I will try using "sudo apt-get remove ..." and see what happens. I can foresee a wonderful afternoon of debugging ;-) I'll get me a nice cup of tea :-D cheers! C. |
April 18, 2012, 11:01 |
Hi Bruno,
I have solved my problem by rewriting the blockMeshDict from scratch. I realized something was going wrong during mesh generation because not all the boundaries defined in my dictionary appeared as generated. Besides, the fact that I was getting velocity vectors through my body's wall had been puzzling ;-) (with non-slip walls) Anyway, my solver is reporting velocity components to the log file. I am attaching the faulty blockMeshDict file if someone want's to investigate. cheers! C. /*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 1.6 | | \\ / A nd | Web: http://www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object blockMeshDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // convertToMeters 1; vertices ( (-2 -0.1 0.5) //0 ( 0 -0.1 0.5) //1 (27 -0.1 0.5) //2 (-2 -0.1 11.5) //3 ( 0 -0.1 11.5) //4 (27 -0.1 11.5) //5 (-2 -0.1 -0.5) //6 ( 0 -0.1 -0.5) //7 (27 -0.1 -0.5) //8 (-2 -0.1 -11.5) //9 ( 0 -0.1 -11.5) //10 (27 -0.1 -11.5) //11 (-2 0.1 0.5) //12 ( 0 0.1 0.5) //13 (27 0.1 0.5) //14 (-2 0.1 11.5) //15 ( 0 0.1 11.5) //16 (27 0.1 11.5) //17 (-2 0.1 -0.5) //18 ( 0 0.1 -0.5) //19 (27 0.1 -0.5) //20 (-2 0.1 -11.5) //21 ( 0 0.1 -11.5) //22 (27 0.1 -11.5) //23 ( 0 -0.1 0) //24 (27 -0.1 0) //25 ( 0 0.1 0) //26 (27 0.1 0) //27 ); blocks // Normals along positive x,y,z ( /* 0 */ hex (ls 0 1 13 12 3 4 16 15) (20 1 110) simpleGrading (1 1 1) /* 1 */ hex ( 1 2 14 13 4 5 17 16) (270 1 110) simpleGrading (1 1 1) /* 2 */ hex (24 25 27 26 1 2 14 13) (270 1 5) simpleGrading (1 1 1) /* 3 */ hex ( 7 8 20 19 24 25 27 26) (270 1 5) simpleGrading (1 1 1) /* 4 */ hex (10 11 23 22 7 8 20 19) (270 1 110) simpleGrading (1 1 1) /* 5 */ hex ( 9 10 22 21 6 7 19 18) (20 1 110) simpleGrading (1 1 1) ); edges ( ); boundary // Normals pointing out of domain ( inlet { type patch; faces ( ( 0 3 15 12) // Block 0 ( 9 6 18 21) // Block 5 ); } outlet { type patch; faces ( ( 5 2 14 17) // Block 1 ( 2 25 27 14) // Block 2 (25 8 20 27) // Block 3 ( 8 11 23 20) // Block 4 ); } skinWall { type wall; faces ( ( 1 0 12 13) // Block 0 ( 6 7 19 18) // Block 5 ) } baseWall { type wall; faces ( ( 24 1 13 26) // Block 2 ( 24 26 19 7) // Block 3 ) } outerDomainUp { type wall; faces ( ( 3 4 16 15) // Block 0 ( 4 5 17 16) // Block 1 ); } outerDomainDown { type wall; faces ( (10 9 21 22) // Block 5 (11 10 22 23) // Block 4 ); } leftAndRight { type empty; faces ( ( 0 1 4 3) // Block 0+ ( 1 2 5 4) // Block 1+ (24 25 2 1) // Block 2+ ( 7 8 25 24) // Block 3+ (10 11 8 7) // Block 4+ ( 9 10 7 6) // Block 5+ (15 16 13 12) // Block 0- (16 17 14 13) // Block 1- (13 14 27 26) // Block 2- (26 27 20 19) // Block 3- (19 20 23 22) // Block 4- (18 19 22 21) // Block 5- ); } ); mergePatchPairs ( ); // ************************************************** *********************** // |
Moving mesh | Niklas Wikstrom (Wikstrom) | OpenFOAM Running, Solving & CFD | 122 | June 15, 2014 07:20 |
Orifice Plate with a fully developed flow - Problems with convergence | jonmec | OpenFOAM Running, Solving & CFD | 3 | July 28, 2011 06:24 |
Differences between serial and parallel runs | carsten | OpenFOAM Bugs | 11 | September 12, 2008 12:16 |
IcoFoam parallel woes | msrinath80 | OpenFOAM Running, Solving & CFD | 9 | July 22, 2007 03:58 |
Could anybody help me see this error and give help | liugx212 | OpenFOAM Running, Solving & CFD | 3 | January 4, 2006 19:07 |
