Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
Data transfer between different foam solvers
Old   March 15, 2012, 20:56
Default Data transfer between different foam solvers
Jeong Kim
enoch is on a distinguished road
I wanted to extract data with the following text format:
x y z Vx Vy Vz
Attahced is a figure where a blue box is an interesting region and needs to be extracted as a text format. This data can be used as a source term for another foam solver. How can I manage to extract the data for the blue domain?
Thanks in advance for your help.
enoch is offline   Reply With Quote
Old   March 16, 2012, 03:32
akidess's Avatar
Anton Kidess
You can use "sample" to postprocess, or "functionObjects" to get the data at runTime.
*On twitter @akidTwit
*Spend as much time formulating your questions as you expect people to spend on their answer.
[Other] mesh airfoil NACA0012 anand_30 OpenFOAM Meshing & Mesh Conversion 13 March 7, 2022 18:22
host_to_node data transfer EllenW Fluent UDF and Scheme Programming 5 May 30, 2009 12:34
need data about oxygen transfer thomas FLUENT 0 April 18, 2004 09:34
Data transfer H. P. LIU Main CFD Forum 5 May 19, 2003 11:47
FOAM licensed free to academic institutions Nabla Ltd. Main CFD Forum 0 November 18, 2002 11:24
